Howto adjust Hitec HS725BB winch servo rotations? Now servo rotates 3 3/4 turns but what i need is much less about 1 3/4. With new computer radios this is not a problem, but in low budget standard 2 channel radio this is an issue.
I find necessary changes for the radio (http://www.rcsailing.gr/tech/tech-winch_turns-eng.htm), but i need my radios for another applications too, so this dosen't help me much. Any suggestions?
How to adjust Hitec HS725BB winch servo rotations?
soeren_andresen
- DEN NCA Officer
- Sail number: 93
- Club: Herslev Strand Sejlklub
- Design: Genesis
HI
I am not electronic nerd, but I think I somewhere on the some thing about this. The problem is that I can not remember where, sorry.
What I do remember is that the tehnic that is used, is very similare to that is done to the Tx. So you can do the same to the servo, insert 2 resistors inline with the pot.
The size of the resistors you will have to find your self, because I have never tried it myself, but I have been told it should work.
I will let you know if I find the site where I found it.
Søren Andresen
Personal sail# DEN 93
I found this on Ken Binks' site at http://www.kbits.co.uk/:
Ken modifies the winch to add a variable resistor on a fly-lead, so you can set the number of turns you want.
K.Bits.. Web site wrote:Hitec adjustable Drum Winch HS-725BB
Price : GBP 54
Catalogue #: WH.005
- Torque 14.5 Kg/cm
- Speed 1.13sec/360 deg
- 6.0 volt
- Throw adjustment: modified by KBits.. to give 1.5 - 4 turns
