How to adjust Hitec HS725BB winch servo rotations?
TWallius
Post by TWallius »
Howto adjust Hitec HS725BB winch servo rotations? Now servo rotates 3 3/4 turns but what i need is much less about 1 3/4. With new computer radios this is not a problem, but in low budget standard 2 channel radio this is an issue.
I find necessary changes for the radio (http://www.rcsailing.gr/tech/tech-winch_turns-eng.htm), but i need my radios for another applications too, so this dosen't help me much. Any suggestions?
Post by ralph kelley »
Here is a simple but crude looking solution.
Cut a piece of light ply to fit into the pot housing. Trim the "horizon" of the piece to limit the stroke of the pot arm to the required amount.
Tape the piece to the pot so that you can remove it easily when you want the TX for other applications
TWallius
Post by TWallius »
This kind of solution i am having right now with my TX. So this is not what i am looking for.
soeren_andresen
DEN NCA Officer
Sail number: 93
Club: Herslev Strand Sejlklub
Design: Genesis
Post by soeren_andresen »
HI
I am not electronic nerd, but I think I somewhere on the some thing about this. The problem is that I can not remember where, sorry. :?:
What I do remember is that the tehnic that is used, is very similare to that is done to the Tx. So you can do the same to the servo, insert 2 resistors inline with the pot.
The size of the resistors you will have to find your self, because I have never tried it myself, but I have been told it should work.
I will let you know if I find the site where I found it.
Søren Andresen
Personal sail# DEN 93
Post by Chairman »
I found this on Ken Binks' site at http://www.kbits.co.uk/:
K.Bits.. Web site wrote:Hitec adjustable Drum Winch HS-725BB
Price : GBP 54
Catalogue #: WH.005
- Torque 14.5 Kg/cm
- Speed 1.13sec/360 deg
- 6.0 volt
- Throw adjustment: modified by KBits.. to give 1.5 - 4 turns
Ken modifies the winch to add a variable resistor on a fly-lead, so you can set the number of turns you want.
tiepje
Post by tiepje »
Make the necessary changes in the transmitter and olso switches.
Switch on the changes are working. :D
Switch off everything is bach to normal. :wink:
sailing now 1 metre, IOM competition
