Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by Mr Graham Elliott »
Post by Lester »
Post by RoyL »
Post by John Ball »
2D.1
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Post by RoyL »
SEBASTIEN LEFEBVRE
Post by SEBASTIEN LEFEBVRE »
I had printed 3 iom boats.
Sébastien LEFEBVRE
Chris Elliott
Sail number: 74
Club: Lincoln
Design: Britpop
Post by Chris Elliott »
Let me put my views on this:
Chris.
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Post by Torsten Kass »
Hallo, ich bin der Neue... :D
Kommen wir aber zu Thema:
Es gibt nur eine Einschränkung für die Filamente - kein Carbon - Ende der Ansage. :P
Chris Spalding
Sail number: 87
Club: Keighley
Design: Sabre
Post by Chris Spalding »
Post by Lester »
Torsten Kass wrote: 22 Nov 2020, 11:47 Courtesy of Google Translate:
Hello, I'm the new one ...: D
But let's get to the topic:
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Ist aber nicht wichtig.
@Lester
Post by Lester »
Torsten Kass wrote: 22 Nov 2020, 15:38 Google translate:
But it is not important.
@Lester
Gabriel Le Duc
Sail number: FRA 08
Club: ASBB
Design: Le Duc Gabriel
Post by Gabriel Le Duc »
Gabriel Le Duc
Gabriel Le Duc
Sail number: FRA 08
Club: ASBB
Now in Google English
Gabriel Le Duc
Juan Marcos Egea
Post by Juan Marcos Egea »
What we see happening:
My conclusions about rules:
Richard Moroney
Sail number: GBR4351
Club: Leicester RYC
Design: Alternative
Post by Richard Moroney »
Richard
Richard
Narrowseas
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Post by Robert Grubisa »
Mr Graham Elliott wrote: 20 Nov 2020, 17:04 Let's all have a discussion in the correct place, the IOMICA forum, and not Facebook or secret emails, yes, an open discussion with even luddites included.
Graham,
All the best
Robert Grubiša
CRO 68
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Hiljoball wrote: 20 Nov 2020, 23:21
2D.1
John,
All the best
Robert Grubiša
CRO 68
PS Original typo corrected.
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
the base material.
Graham Bantock
* author emphasis added
end
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Robert Grubiša
CRO 68
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Juan Marcos Egea wrote: 23 Nov 2020, 13:42 Hi everybody, and thank you Graham for the initiative.
Hi Juan Marcos,
Full agreed with your post.
Robert Grubiša
CRO 68
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Mr Graham Elliott wrote: 23 Nov 2020, 21:11 Yes, just using this open forum to, as I said, 'come to an agreed wording and get the motion passed'.
Graham,
Robert Grubiša
CRO 68
Post by Lester »
The question
Conclusions
Laws of physics.xlsx
Excel file
(12.08 KiB) Downloaded 34727 times
3D printing.pdf
PDF file
(491.09 KiB) Downloaded 36948 times
Mr Graham Elliott
Sail number: 09
Club: Birkenhead
Design: britpop
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Lester wrote: 23 Nov 2020, 21:47
Conclusions
Thanks for interesting article. I am not questioning the law of physics at all :wink: but take into consideration the following assumption.
What if somebody conclude that the current "traditional" :wink: moulded glass/epoxy hulls are simply unnecessary stiff and long-lived and that for the top results you don't need such "extra stiffness" and that the risk of collision and total loss of the boat is not so high.... And that such skipper manage to make a hull using new technologies (one of them is 3D printing). Note, building techniques are not restricted..... And that such skipper/builder produce the hull with different thickness of hull skin so the ends are lighter than the middle part of the boat. And that some XYZ commercial manufacturer is starting to advertising and selling such IOM boats as the state-of-the-art product using the latest additive manufacturing etc etc in compliance with the IOM Class Rules. Do we want that? I don't.
All the best
Robert Grubiša
CRO 68
Torsten Kass
Sail number: GER 75
Club: VdMYS
Design: Incognito
Noch eine wichtige Sache:
Post by Lester »
Robert Grubisa wrote: 24 Nov 2020, 13:51 What if [...] the hull with different thickness of hull skin [...] advertising and selling such IOM boats as the state-of-the-art?
Hi Robert
Robert Grubisa wrote: 24 Nov 2020, 13:51 [...] honeycombing (infill) is not allowed because if it is allowed for 3D printed boats why to prohibit it on the moulded boats?
Prohibited for moulding because the 3D printed hull is thermoplastic, whereas the moulded hull is thermoset.
Robert Grubisa wrote: 24 Nov 2020, 13:51 3D printing of honeycombed material as a core between two layers of moulded skins is the possible loophole if you allow the 3d printing with honeycombing.
I don't understand why this is a "loophole". I can see no problem to have a 3D printed thermoplastic honeycomb which is a core between two layers of glass fibre skin. Thermoplastic is much weaker than almost any other material of interest, and the only way to get strength and stiffness is to make it thick. When thick, it is heavy, so we honeycomb it. The laws of physics tell us that a honeycombed thermoplastic is somewhere between twice and four times as heavy as a thin material for equivalent strength and stiffness. But I will check this, I can construct and test a desktop model of a 3D printed honeycombed nylon sheet between two thin g/f sheets and let you know the outcome.
