- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
- Sail number: GBR 105
- Design: Pikanto
2D.1
2D.1
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
SEBASTIEN LEFEBVRE
I had printed 3 iom boats.
Sébastien LEFEBVRE
Sébastien LEFEBVRE
Chris Elliott
- Sail number: 74
- Club: Lincoln
- Design: Britpop
Let me put my views on this:
Chris.
Chris.
Torsten Kass
- Sail number: GER 75
- Club: VdMYS
- Design: Incognito
Hallo, ich bin der Neue...
Kommen wir aber zu Thema:
Es gibt nur eine Einschränkung für die Filamente - kein Carbon - Ende der Ansage.
Chris Spalding
- Sail number: 87
- Club: Keighley
- Design: Sabre
- Design: Pikanto
Torsten Kass wrote: 22 Nov 2020, 11:47 Courtesy of Google Translate:
Hello, I'm the new one ...: D
But let's get to the topic:
Torsten Kass
- Club: VdMYS
- Design: Incognito
Ist aber nicht wichtig.
@Lester
@Lester
- Design: Pikanto
Torsten Kass wrote: 22 Nov 2020, 15:38 Google translate:
But it is not important.
@Lester
Gabriel Le Duc
- Sail number: FRA 08
- Club: ASBB
- Design: Le Duc Gabriel
Gabriel Le Duc
Gabriel Le Duc
Gabriel Le Duc
- Club: ASBB
Now in Google English
Gabriel Le Duc
Gabriel Le Duc
Juan Marcos Egea
What we see happening:
My conclusions about rules:
Richard Moroney
- Sail number: GBR4351
- Club: Leicester RYC
- Design: Alternative
Richard
Richard
Richard
Narrowseas
Narrowseas
- Sail number: CRO 68
- Club: JK Opatija
- Design: Alioth V4
Graham,Mr Graham Elliott wrote: 20 Nov 2020, 17:04 Let's all have a discussion in the correct place, the IOMICA forum, and not Facebook or secret emails, yes, an open discussion with even luddites included.
All the best
Robert Grubiša
CRO 68
- Club: JK Opatija
- Design: Alioth V4
John,Hiljoball wrote: 20 Nov 2020, 23:21
2D.1
All the best
Robert Grubiša
CRO 68
PS Original typo corrected.
- Club: JK Opatija
- Design: Alioth V4
the base material.
Graham Bantock
* author emphasis added
end
the base material.
Graham Bantock
end
- Club: JK Opatija
- Design: Alioth V4
Robert Grubiša
CRO 68
Robert Grubiša
CRO 68
- Club: JK Opatija
- Design: Alioth V4
Juan Marcos Egea wrote: 23 Nov 2020, 13:42 Hi everybody, and thank you Graham for the initiative.
Hi Juan Marcos,
Full agreed with your post.
Robert Grubiša
CRO 68
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
- Club: JK Opatija
- Design: Alioth V4
Mr Graham Elliott wrote: 23 Nov 2020, 21:11 Yes, just using this open forum to, as I said, 'come to an agreed wording and get the motion passed'.
Graham,
Robert Grubiša
CRO 68
- Design: Pikanto
The question
Conclusions
The question
Conclusions
- Laws of physics.xlsx
- Excel file
- (12.08 KiB) Downloaded 34727 times
- 3D printing.pdf
- PDF file
- (491.09 KiB) Downloaded 36948 times
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
- Club: JK Opatija
- Design: Alioth V4
Hi Lester,Lester wrote: 23 Nov 2020, 21:47
Conclusions
Thanks for interesting article. I am not questioning the law of physics at all
What if somebody conclude that the current "traditional"
All the best
Robert Grubiša
CRO 68
Torsten Kass
- Club: VdMYS
- Design: Incognito
Noch eine wichtige Sache:
- Design: Pikanto
Hi RobertRobert Grubisa wrote: 24 Nov 2020, 13:51 What if [...] the hull with different thickness of hull skin [...] advertising and selling such IOM boats as the state-of-the-art?
Prohibited for moulding because the 3D printed hull is thermoplastic, whereas the moulded hull is thermoset.Robert Grubisa wrote: 24 Nov 2020, 13:51 [...] honeycombing (infill) is not allowed because if it is allowed for 3D printed boats why to prohibit it on the moulded boats?
I don't understand why this is a "loophole". I can see no problem to have a 3D printed thermoplastic honeycomb which is a core between two layers of glass fibre skin. Thermoplastic is much weaker than almost any other material of interest, and the only way to get strength and stiffness is to make it thick. When thick, it is heavy, so we honeycomb it. The laws of physics tell us that a honeycombed thermoplastic is somewhere between twice and four times as heavy as a thin material for equivalent strength and stiffness. But I will check this, I can construct and test a desktop model of a 3D printed honeycombed nylon sheet between two thin g/f sheets and let you know the outcome.Robert Grubisa wrote: 24 Nov 2020, 13:51 3D printing of honeycombed material as a core between two layers of moulded skins is the possible loophole if you allow the 3d printing with honeycombing.
