winch or arm servo?
Sail number: GBR3845
Club: Eastbourne
Design: TS2 and Shiraz
winch or arm servo?
Post by Dave Pickett »
Neil Armstrong
Sail number: GBR 13
Design: Mallard
Re: winch or arm servo?
Post by Neil Armstrong »
Hi David,
Aaron Plazier
Sail number: AUS-TBA
Club: TBA
Design: TBA
Post by Aaron Plazier »
Dave I am no expert :P but I ordered a Hitec HS-785HB Sail winch servo for my 1st boat.
No way in same league as the RMG ones but for me it's fine to do my apprenticeship with. :lol:
Vice-chairman (Events)
Sail number: FRA 100
Design: Venti
Post by Olivier Cohen »
RMG is the easy way.
Club: Eastbourne
HS-785HB
Post by Bruce Andersen »
Aaron Plazier
Club: TBA
Design: TBA
Rudder servos?
4.8v torque 8kg/cm
6v torque 11kg/cm
Patrick Parisienne
Sail number: AUS 38
Design: Obsession
Post by Patrick Parisienne »
Pat
Aaron Plazier
Club: TBA
Design: TBA
thanks for that!
Ralph Knowles
Post by Ralph Knowles »
Bring on the Breeze!
Club: Eastbourne
Gyula
Sail number: ROU 52
Design: Ska
Post by Gyula »
Gyula Ferencz
Club: Eastbourne
