winch or arm servo?
- Sail number: GBR3845
- Club: Eastbourne
- Design: TS2 and Shiraz
winch or arm servo?
- Sail number: GBR 13
- Design: Mallard
Re: winch or arm servo?
Hi David,
- Sail number: AUS-TBA
- Club: TBA
- Design: TBA
Dave I am no expert but I ordered a Hitec HS-785HB Sail winch servo for my 1st boat.
No way in same league as the RMG ones but for me it's fine to do my apprenticeship with.
- IOMICA Chairman
- Sail number: FRA 100
- Design: Venti
RMG is the easy way.
- Club: Eastbourne
Thanks, although I really like the simplicity of an arm servo, I will give this some serious thought, maybe running on 7.4volt lipo it will be quick enough.....HS-785HB
- USA NCA Officer
Chairman, IRSA
Chairman, IRSA
- Club: TBA
- Design: TBA
Rudder servos?
4.8v torque 8kg/cm
6v torque 11kg/cm
Rudder servos?
4.8v torque 8kg/cm
6v torque 11kg/cm
- Sail number: AUS 38
- Design: Obsession
Pat
Pat
- Club: TBA
- Design: TBA
thanks for that!
Bring on the Breeze!
- Club: Eastbourne
- Sail number: ROU 52
- Design: Ska
I have found some info about the Eurgle winches:
http://homepage.ntlworld.com/k.partington/eurgle.doc
http://midlanddistrictmya.wordpress.com ... pers-view/
Gyula Ferencz
- Club: Eastbourne
