- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
2D.1
2D.1
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
I had printed 3 iom boats.
Sébastien LEFEBVRE
Sébastien LEFEBVRE
- Sail number: 74
- Club: Lincoln
- Design: Britpop
Let me put my views on this:
Chris.
Chris.
- Sail number: GER 75
- Club: VdMYS
- Design: Incognito
Hallo, ich bin der Neue...
Kommen wir aber zu Thema:
Es gibt nur eine Einschränkung für die Filamente - kein Carbon - Ende der Ansage.
- Sail number: 87
- Club: Keighley
- Design: Sabre
Torsten Kass wrote: ↑22 Nov 2020, 11:47Courtesy of Google Translate:
Hello, I'm the new one ...: D
But let's get to the topic:
- Club: VdMYS
- Design: Incognito
Ist aber nicht wichtig.
@Lester
@Lester
Torsten Kass wrote: ↑22 Nov 2020, 15:38Google translate:
But it is not important.
@Lester
- Sail number: FRA 08
- Club: Club Nautique Cap d'Agde
- Design: Le Duc Gabriel
Gabriel Le Duc
Gabriel Le Duc
Now in Google English
Gabriel Le Duc
Gabriel Le Duc
What we see happening:
My conclusions about rules:
- Sail number: GBR4351
- Club: Leicester RYC
- Design: Alternative
Richard
Richard
Richard
Narrowseas
Narrowseas
- Vice-chairman (Technical)
- Sail number: CRO 68
- Club: JK Opatija
- Design: Kantun 2
Graham,Mr Graham Elliott wrote: ↑20 Nov 2020, 17:04Let's all have a discussion in the correct place, the IOMICA forum, and not Facebook or secret emails, yes, an open discussion with even luddites included.
All the best
Robert Grubiša
CRO 68
- Club: JK Opatija
- Design: Kantun 2
John,Hiljoball wrote: ↑20 Nov 2020, 23:21
2D.1
All the best
Robert Grubiša
CRO 68
PS Original typo corrected.
- Club: JK Opatija
- Design: Kantun 2
the base material.
Graham Bantock
* author emphasis added
end
the base material.
Graham Bantock
end
- Club: JK Opatija
- Design: Kantun 2
Robert Grubiša
CRO 68
Robert Grubiša
CRO 68
- Club: JK Opatija
- Design: Kantun 2
Juan Marcos Egea wrote: ↑23 Nov 2020, 13:42Hi everybody, and thank you Graham for the initiative.
Hi Juan Marcos,
Full agreed with your post.
Robert Grubiša
CRO 68
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
- Club: JK Opatija
- Design: Kantun 2
Mr Graham Elliott wrote: ↑23 Nov 2020, 21:11Yes, just using this open forum to, as I said, 'come to an agreed wording and get the motion passed'.
Graham,
Robert Grubiša
CRO 68
The question
Conclusions
The question
Conclusions
- Laws of physics.xlsx
- Excel file
- (12.08 KiB) Downloaded 13162 times
- 3D printing.pdf
- PDF file
- (491.09 KiB) Downloaded 13425 times
- Mr Graham Elliott
- Sail number: 09
- Club: Birkenhead
- Design: britpop
- USA NCA Officer
- Club: JK Opatija
- Design: Kantun 2
Hi Lester,Lester wrote: ↑23 Nov 2020, 21:47
Conclusions
Thanks for interesting article. I am not questioning the law of physics at all but take into consideration the following assumption.
What if somebody conclude that the current "traditional" moulded glass/epoxy hulls are simply unnecessary stiff and long-lived and that for the top results you don't need such "extra stiffness" and that the risk of collision and total loss of the boat is not so high.... And that such skipper manage to make a hull using new technologies (one of them is 3D printing). Note, building techniques are not restricted..... And that such skipper/builder produce the hull with different thickness of hull skin so the ends are lighter than the middle part of the boat. And that some XYZ commercial manufacturer is starting to advertising and selling such IOM boats as the state-of-the-art product using the latest additive manufacturing etc etc in compliance with the IOM Class Rules. Do we want that? I don't.
All the best
Robert Grubiša
CRO 68
- Club: VdMYS
- Design: Incognito
Noch eine wichtige Sache:
Hi RobertRobert Grubisa wrote: ↑24 Nov 2020, 13:51What if [...] the hull with different thickness of hull skin [...] advertising and selling such IOM boats as the state-of-the-art?
