The Technical SC and Measurement SC are in addition considering steps that might be taken to address the issue of manufacturers driving class development rather than the class association.IOMICA official advice wrote:Item (1) derives from the consumer legislation that is in place in most countries, and is an implicit condition of trade otherwise. Something for sale must be fit for its purpose, and the manufacturer has liability if not a duty of care for it. It does not prevent any manufacturer agreeing with a customer that a particular item is "by special request of the customer" and is sold without representation or warranty of any kind. No problem in this case.
- If you are a commercial manufacturer supplying equipment to the class, treat new ideas as if they are probably illegal. Convince yourself that it is not so before marketing the equipment. Consider asking the IOMICA TSC for an interpretation. If you sell equipment that is found to be illegal you may be obliged to correct, or replace, the equipment at your own expense.
- If you are an amateur builder and come up with something you have not seen before, then assume that it is illegal until you are convinced otherwise. Direct any questions to your national class association.
- A certificate, or a certification mark, is NOT proof of the equipment being class legal. It is only proof that the equipment has passed such controls as are required by the class rules, and that the official measurer at the time of fundamental measurement did not find anything wrong with the equipment.
- The owner always has the responsibility for the use of class-legal equipment, RRS 78.1 applies.
IOMICA advice on "new ideas" and the class rules
The Executive, in consultation with the World Council, will shortly publish official advice on the class rules and new ideas, as follows:
- Zoltan G Illes
- Vice-chairman (Infocomms)
- Sail number: HUN77
- Club: DEMK
Re: IOMICA advice on "new ideas" and the class rules
I find the word “illegal” used in this context slightly harsh and would instead prefer a formulation like “against the class rules”.
What happens when you are a manufacturer and VC Technical? Should that be where IRSA steps in to adjudicate?
in my private capacity, not as Chairman of IRSA
still good advice though
- Zoltan G Illes
- Club: DEMK
Haha, yes, a really old post. Usually I try to watch out for these things, but this time I was too fast. Mer culpa!
