Roy:
RoyL wrote:The continued use of the word "racing" in our class rule regarding restrictions on the movement of corrector weights is clearly an oversight by the perfectly human drafters of our rules. Read in context and in light of all the rest of our rules the word should be read to mean "event" or "regatta".
I hardly think this is the case! The issue is that the "perfectly human" drafters of our rules had
no reason to consider restrictions on movement of corrector weights because they drafted those rules in the period of time RRS2001-2004 was in effect which contained a rule (E4.7 - see Lester's post below for the entire text of the old rule) that took care of all of those details (in a fashion that clearly applied to the whole event).
RSD decided (rightly IMHO) to dispense with this rule for the next edition of RRS (2005-2008) in order that the individual classes get to choose (and state so in their own CRs) whether moving various types of ballast was acceptable or not rather than have such a constraint built in at the RRS level. The idea, I imagine, was that some developmental classes would probably want to be able to not only move the corrector weights but also to have moving ballast - like canting keels or rail-ballast and they should not be prevented from that in the RRS.
As a result - clearly the drafters did not make any errors but rather were unaware at the time of the initial drafting of the rule that they were required to consider movement of corrector weights (they were "covered" by E4.7).
{Incidentally, people made all the fuss in this thread discussing the use/meaning/context/whathaveyou of the word "fixed" in the C.4.3 whereas I always thought that the real emphasis there was on "in/on the hull"
RoyL wrote:A literal reading of the rule would lead to the absurd result that the only time you could not move corrector weights was when the boat was sailing--the one time it is impossible to, in fact, move corrector weights. If that was the true the rule would be totally absurd and have no practical meaning or purpose.
Again - I have to disagree Roy... It only
seeems absurd to you because you are "blinded" by your intent that the corrector weights should somehow inherently be immovable... Some classes may want to have this extra variable to play with trim adjustment during racing. IOM owners clearly do not - but that does not mean that the rule is absurd or nonsensical...
Being able to move/adjust something at any time except when you are racing is pretty much "par for the course". Think of masts for example - we can adjust position and rake (and even change the whole rig) at any time (except when we're racing). Nothing absurd about that! If we want additional restrictions to be in place - we have to spell them out.
In fact, the literal reading of C.4.3 is perfectly clear and anything but absurd. It:
- allows you to
have corrector weights (as per our closed CRs this is necessary)
- requires that those corrector weights be attached to the (inside or outside of the) hull (as opposed to a mast or appendage or something else)
Nothing more and nothing less (for now) - but I certainly see nothing absurd about it.
RoyL wrote:As to the need for an emergency rule change, since Spain made a request for an official "interpretation" of the meaning of this section, the position of VC Technical is that the literal language of the rule is effectively a typographical error. The word "event" should be considered substituted for the word "racing".
This is consistent with prior technical interpretations such as that concerning the jib attachment to the boom where literal language was also held to be a typographical error.
Although, as you say, there was a prior interpretation that was upheld that claimed a certain rule contained a typographical/language error - I can hardly see this line of reasoning applied in this case...
What
exactly is the typo?
Surely
not that the entire section C should be in force "for the duration of the event" rather than "while racing"? This is part of the SCR and is written like that for any other international sailing class (large or small) that adopted SCR. Surely THAT's not a typo?
RoyL wrote:This official interpretation of VC Technical is now public. If RSD (Robert Grubisa) accepts it, the issue is closed. If Robert does not, I assume it will be included in the package of proposed rule changes/interpretations that will be forwarded to ISAF. I believe ISAF will in all likelihood accept this ruling.
Personally, Roy, I would be very surprised if the "typo" interpretation is accepted even by RSD/Robert (who may be sympathetic to the issue - probably himself not wishing to allow moving of the corrector weights) but I would be absolutely shocked if completely impartial (professional) rule gurus at ISAF accept it...
Why not just put forward emergency rule change (picking one of the two proposed verbiages) which will then get ratified at the AGM (anyway)?
