Dear Roy, I also use the Velcro solution to fix the corrector weights to my boat and I have no doubt that I comply with the rules.As to your velcro suggestion please explain how attachment with velcro is "fixed" or "permanent".
According with the dictionary to fix means attach or position securely.
So, in my opinion, if you put a boat upside down or you shake it and nothing happens then it is clear that the boat complies with the rule.
On the other hand I don’t know why you say that the corrector weights need to be fixed in a “permanentâ€
