Post
by Lester » 28 Nov 2007, 21:32
In common with a number of owners, I've fitted Rob Guyatt's little battery voltage flashing display thingy on my pot lid (
http://www.onemetre.net/OtherTopics/Flash/Flash.htm). Turns out this might not meet the IOM class rules:
(1) One receiver.
(2) One rudder control unit.
(3) One sheet control unit.
Post
by Steve Landeau » 30 Nov 2007, 19:11
Hi, Lester.
Post
by Barry Fox CAN262 » 01 Dec 2007, 07:45
Gilbert Louis
Post
by Gilbert Louis » 03 Dec 2007, 01:24
Hi,
Gilbert
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
Post
by RoyL » 11 Feb 2008, 20:36
Post
by Ken Dobbie » 12 Feb 2008, 05:59
Ken
- USA NCA Officer
Post
by Bruce Andersen » 12 Feb 2008, 07:15
- IOMICA Chairman
Post
by Alfonso » 12 Feb 2008, 11:43
I agree 100% with Ken.
JThompson
Post
by JThompson » 06 Apr 2008, 07:20
Jim
Jim Thompson
IOM - USA 370 - Ericca
Hiljoball
Post
by Hiljoball » 06 Apr 2008, 22:21
Post
by RoyL » 07 Apr 2008, 00:54
Gilbert Louis
Post
by Gilbert Louis » 07 Apr 2008, 12:50
Gilbert LOUIS
www.iomireland.org
IRL41 - Ireland
Post
by RoyL » 07 Apr 2008, 19:08
paulo gomes
- Sail number: POR56
- Club: Clube Naval Povoense
- Design: BritPop
Post
by paulo gomes » 01 Oct 2008, 16:18
Hello from Portugal,
Our very best regards
APMV
Portugal
- IOMICA Chairman
Post
by Olivier Cohen » 01 Oct 2008, 16:53
100% OK with that
- GBR NCA Officer
Post
by Andy Stevenson » 01 Oct 2008, 19:26
Hi Paulo
Post
by Steve Landeau » 01 Oct 2008, 20:05
- GBR NCA Officer
Post
by Andy Stevenson » 01 Oct 2008, 20:15
Hi Steve
Post
by Barry Fox CAN262 » 01 Oct 2008, 23:11
Hiljoball
Post
by Hiljoball » 01 Oct 2008, 23:30
Post
by Steve Landeau » 01 Oct 2008, 23:48
Post
by Barry Fox CAN262 » 02 Oct 2008, 00:30
Post
by RoyL » 02 Oct 2008, 07:19
- IOMICA Chairman
Post
by Alfonso » 02 Oct 2008, 09:39
Stefano Savelli
- ITA NCA Officer
Post
by Stefano Savelli » 02 Oct 2008, 13:18
hello to all,
Stefano Savelli (Ita54)
Stefano Savelli
SAVELLI S.r.l.
Via Bergamo 2/1a
23875 Osnago (LC)
Post
by Don Case » 02 Oct 2008, 17:29
Hiljoball
Post
by Hiljoball » 02 Oct 2008, 17:30
Post
by Barry Fox CAN262 » 02 Oct 2008, 18:46
C5.3
- USA NCA Officer
Post
by Bruce Andersen » 03 Oct 2008, 06:14
Post
by Barry Fox CAN262 » 03 Oct 2008, 07:04
