![Image](tag.%20%20Here,%20for%20example,%20is%20the%20picture%20on%20the%20home%20page%20of%20the%20IOMICA%20Web%20site%20inserted%20into%20the%20message%20%28using%20square%20brackets%20instead%20of%20curly%20ones%29%20like%20this:%20%22%7Bimg%7Dhttp%3A//www.iomclass.org/HomePics/Trevor.jpg%7B/img%7D%22.%20%20The%20image%20has%20been%20centered%20by%20using%20the%20HTML%20tag%20%22CENTER%22.%0A%0AOh,%20just%20one%20thing%20--%20please%20%5Bb%5D%5Bcolor=red%5Ddon%27t%5B/color%5D%5B/b%5D%20link%20to%20350%20kb-size%20JPGs%20in%20fabulous%201600%20x%201200%20resolution,%20they%20take%20an%20age%20to%20download%20and%20some%20of%20us%20are%20still%20using%2056%20kbit%20modems.%20%20Also,%20an%20image%20much%20wider%20than%20around%20600%20pixels%20forces%20horizontal%20scrolling%20for%20all%20other%20posts%20to%20that%20topic.%20%20This%20is%20%5Bb%5Dseriously%5B/b%5D%20annoying%20for%20readers.%20%20An%20image%20smaller%20than%20about%20400%20x%20400%20is%20much%20better%20%28Trevor%20here%20is%20300%20x%20400%29,%20otherwise%20please%20just%20give%20us%20the%20URL.%20%20%5Bsize=75%5DThe%20HTML%20%22IMG%22%20tag%20is%20enabled%20in%20the%20board.%20%20This%20allows%20you%20to%20use%20the%20%22WIDTH%22%20attribute%20of%20the%20tag%20if%20you%20simply%20%5Bi%5Dmust%5B/i%5D%20show%20an%20image%20that%20is%20otherwise%20wider%20than%20the%20%27normal%27%20width%20for%20a%20post%20--%20typically%20600.%5B/size%5D%0A%0A%3CCENTER%3E%5Bimg%5Dhttp://www.iomclass.org/regattas/Trevor.jpg)
Links can also be shown in your posts. Use the BBCode tag. To show the link to the IOMICA ov ... erview.htm
You can provide a link to a document file, for example http://www.iomclass.org/Information/Dow ... Aprog5.doc. A member can view the file by clicking on it, and it will open in a new window. Alternatively, a member can download the file by right-clicking on the link and asking to "Save as...".
