IOM Fin material
Maurice
IOM Fin material
Post by Maurice » 13 Apr 2005, 08:02
Perhaps someone may be able to settle a discusion that is current in our club at the moment, are alluminium finns allowed in the rules ?? and if so is any one using them in competitions' ? :idea: :?
edmorales
Post by edmorales » 13 Apr 2005, 08:31
having aluminum as a keel fin and lead as ballast in the presence of water can cause the aluminum to corrode due to galvanic process. disimilar metals are not recommended to sit next to each other unless either is coated with dacromet.
ed
spaldi01
Post by spaldi01 » 13 Apr 2005, 09:32
Aluminium fins are allowed there is a boat at our club with one
Sail number:USA 12
Design:Which One
Post by Steve Landeau » 14 Apr 2005, 05:06
edmorales wrote:having aluminum as a keel fin and lead as ballast in the presence of water can cause the aluminum to corrode due to galvanic process. disimilar metals are not recommended to sit next to each other unless either is coated with dacromet.
ed
True, but in reality our boats spend very little time overall in the water. Aluminum fins are used commonly here in SoCal, and I've not seen any negative issues.
edmorales
Post by edmorales » 14 Apr 2005, 07:58
how can the desired thickness/chord/foil shape be achieved on an aluminum billet? cnc milling? casting? drop forged? will a flat plate be effective? what about torsional stiffness?
ed
Maurice
Post by Maurice » 14 Apr 2005, 10:06
ED i WOULD COVER THE ALLY PLATE WITH FIBRE GLASS AND RESIN . THUS BEING ABLE TO GIVE SHAPE , STIFNES, AND PROTECTION FROM THE ELEMENTS. THANKS TO EVERY ONE FOR THERE COMMENTS. :D :D
Sail number:USA 12
Design:Which One
Post by Steve Landeau » 14 Apr 2005, 16:44
The ones I've seen are milled.
Post by Chairman » 14 Apr 2005, 20:55
edmorales wrote:will a flat plate be effective?
A flat plate as a fin can be remarkably effective, especially if you do your best to round the leading edge, and chamfer the trailing edge. It'll never be as good as a "proper" foil with a "proper" aerofoil section, because it will stall rather early, its maximum lift will be modest, and it will give generally higher drag throughout. Apart from that, no problem!
