Single Panel Molded Sails
Alfonso
Re: Single Panel Molded Sails
Post by Alfonso »
Hi Bruce,
TedFlack
Post by TedFlack »
Post by Bruce Andersen »
Thanks for asking.
Alfonso
Post by Alfonso »
Hi Bruce,
Alfonso
Post by John Ball »
Post by RoyL »
Post by Barry Fox CAN262 »
Alfonso
Post by Alfonso »
Hi John,
Dave Alston
Sail number: GBR3096
Club: Market Bosworth
Design: Fatboy
Post by Dave Alston »
Gentlemen,
and retaining
Dave A
TedFlack
Post by TedFlack »
Alfonso wrote:Hi John,
I've been thinking :roll: : Perhaps the only way to settle this sails issue (if we have one) is by controlling the material that is used to make them.
Peter Allen
Post by Peter Allen »
Post by John Ball »
G.3.1 CONSTRUCTION
(a) MANDATORY
and
G.3.2 CONSTRUCTION TECHNIQUES
beyond the edges of the seam.
How does this approach work?
TedFlack
Post by TedFlack »
Peter Allen wrote:Ted,i hear what you're saying but i don't know what you're thinking. Peter
Peter,
Ted
Alfonso
Post by Alfonso »
Hi John,
Dave Alston
Design: Fatboy
Ted
Alfonso
Gentlemen
Post by John Ball »
Hi Dave,
TedFlack
Post by TedFlack »
Dave,
Ted
Dave Alston
Design: Fatboy
Ted,
But I digress….
Post by RoyL »
Dave Alston
Design: Fatboy
Roy,
Dave Alston
Design: Fatboy
Antonio Espada
Sail number: ESP 3
Club: NAUTICO VILANOVA
Design: ICEPICK
Post by Antonio Espada »
Antonio.
Antonio Espada
SCIRA CHIEF MEASURER
ESP 03
Sail number: CRO 68
Club: JK Opatija
Design: Alioth V4
Post by Robert Grubisa »
Hi all
Don Case
Post by Don Case »
Can224
Zvonko wrote:Dear all
Don Case
Can 271
Vancouver Island B.C.
Hi Don,
Just a guess.
Post by John Ball »
Nigel
Post by Nigel »
Hi John,
Dick Carver
Post by Dick Carver »
Nigel wrote:Hi John,
Agreed.
Dick Carver
Post by RoyL »
