Sail number: GBR3845
Club: Eastbourne
Design: TS2 and Shiraz
Post by Dave Pickett »
And how long do they last?
Post by John Ball »
chris sullivan
Sail number: us 462
Club: NBRCSC
Design: errica
Post by chris sullivan »
stats - 2s2p cells
3.2 oz/90.7g
50x30x31mm
sully
Post by Bruce Andersen »
Peter Allen
Post by Peter Allen »
Peter Allen
Club: Eastbourne
Peter Allen
Post by Barry Fox CAN262 »
Peter Allen
I'm happy.
Peter Allen
Club: Eastbourne
Peter Allen
Peter Allen
Peter Allen
Club: Eastbourne
Gyula
Sail number: ROU 52
Design: Ska
Post by Gyula »
Gyula Ferencz
Peter Allen
Club: Eastbourne
Peter Allen
Club: Eastbourne
Peter,
I am using this one:
Peter Allen
Club: Eastbourne
Guys,
To confirm for total clarity
