Sheet winches
Nigel28
Sail number: CAN 28
Design: Vancouver
Sheet winches
Post by Nigel28 » 16 Mar 2004, 17:44
Nigel Ashman
CAN 328
spaldi01
Post by spaldi01 » 17 Mar 2004, 15:27
Greg Vasileff
Post by Greg Vasileff » 17 Mar 2004, 18:49
8) ......Futaba s5801..... 8)
I know there has been some bad rap on these, but I use 5 of them now, some for three years, and I've never had any problems.
Greg V
Post by Steve Landeau » 18 Mar 2004, 07:22
Greg Vasileff wrote:8) ......Futaba s5801..... 8)
There are 2 kinds of 5801 owners,
Post by edmorales » 18 Mar 2004, 09:18
hello guys!
my iom has the rmg 280c. has anybody tried upgrading a 280c to the d model? is this feasible?
ed morales :?:
Brad Gibson
Post by Brad Gibson » 18 Mar 2004, 10:29
Hi Ed,
As allways it comes down to personal preference (& what can be easily fitted to your hull :D ).
BG
Post by edmorales » 18 Mar 2004, 11:22
hello brad,
thanks for the input.i guess the upgrade from "c" to "d" would be a wise investment. i'll get to save some bucks. the only downside is that my boat will have to be winchless a few weeks while the winch gets a brain transplant.
regards
ed morales :idea:
Post by Steve Landeau » 18 Mar 2004, 15:58
Hi, Ed.
I'll bet if you notify Rob that it's coming, you'll only be waiting for shipping time. He'll turn it quickly.
The Aus. Airmail is better than our USPS!. I guess it's cause we're on the west coast, but my shipping is only 3 days.
ron
sheet winches
Post by ron » 18 Mar 2004, 19:15
hi ed,
ron
Jeff Kay
IRL NCA Officer
Post by Jeff Kay » 18 Mar 2004, 20:12
Jeff
whirlwind winches
Post by edmorales » 12 Apr 2004, 14:22
hmmmmm...whirlwind has closed shop
http://www.whirlwindwinches.co.uk/ :!:
