Stephen Robinson
Sail number:317
Design:Tribute
Australia
Post by Stephen Robinson » 07 Nov 2024, 10:27
Sail number:USA 16
Design:Brit Pop
Post by Bruce Andersen » 13 Nov 2024, 22:42
Stephen Robinson
Sail number:317
Design:Tribute
Australia
Post by Stephen Robinson » 14 Nov 2024, 07:04
Thanks Bruce.
Sail number:USA 16
Design:Brit Pop
Post by Bruce Andersen » 14 Nov 2024, 17:07
Stephen Robinson
Sail number:317
Design:Tribute
Australia
Post by Stephen Robinson » 15 Nov 2024, 04:23
Bruce Andersen wrote:
14 Nov 2024, 17:07
Thanks. Will have a look.
Vice-chairman (Events)
Sail number:FRA 100
Design:Venti
France
Post by Olivier Cohen » 18 Nov 2024, 13:35
Stephen Robinson
Sail number:317
Design:Tribute
Australia
Post by Stephen Robinson » 19 Nov 2024, 06:03
Olivier Cohen wrote:
18 Nov 2024, 13:35
Thanks Oliver.
Art Prufer
Sail number:CAN 42
Club:WCRS -West Coast Radio Sailing
Design:Corbie 6
Post by Art Prufer » 09 Dec 2024, 17:28
Art Prufer
CRYA #1189 Can 42
Stephen Robinson
Sail number:317
Design:Tribute
Australia
Post by Stephen Robinson » 12 Dec 2024, 05:25
Thanks Art. :D
