Stephen Robinson
Sail number: 317
Design: Tribute
Post by Stephen Robinson »
Post by Bruce Andersen »
Stephen Robinson
Sail number: 317
Design: Tribute
Thanks Bruce.
Stephen Robinson
Sail number: 317
Design: Tribute
Bruce Andersen wrote: 14 Nov 2024, 17:07 If you're determined to use a switch, use a SmartSwitch from RMG - it is sealed, shows battery charge status at a glance, and is flat to eliminate line snags
Thanks. Will have a look.
Vice-chairman (Events)
Sail number: FRA 100
Design: Venti
Post by Olivier Cohen »
Stephen Robinson
Sail number: 317
Design: Tribute
Olivier Cohen wrote: 18 Nov 2024, 13:35 When I had an armwinch with battery connected directly to the receiver, I used a wire connected to the receiver with on the other side a plug such as XT60 to connect my battery on it. As you say, less dangerous for receiver's pins.
Thanks Oliver.
Art Prufer
Sail number: CAN 42
Design: Corbie 6
Post by Art Prufer »
Art Prufer
CRYA #1189 Can 42
Stephen Robinson
Sail number: 317
Design: Tribute
Thanks Art. :D
