Files for the 2026 AGM
Posted: 25 Sep 2026, 22:24
by Zoltan G Illes
Her you can find the files for the 2026 AGM
Re: Files for the 2026 AGM
Posted: 26 Sep 2026, 17:42
by John Ball
For the proposal to change the size for sail numbering, the motion refers to replacing Appendix E8 G1.4 with numbered items (1) and (2), however the correct reference should be E8 G1 (a) and (b).
Posted: 27 Sep 2026, 00:24
by Andrew Crocker
Thanks for your comments. The wrong file was uploaded as Proposal 2026-3 - the correct file is attached and, hopefully, it has the correct RRS references. Microsoft Word can have a mind of its own on numbering
. The explanatory document (Legibility of Sail Numbers) was uploaded twice (the second time as Proposal 2026-3). Regardless of the RRS reference, it remains the best explanation of the reasoning behind the specifics of the proposed change.
Posted: 27 Sep 2026, 05:04
by John Ball
Thanks Andrew.
That looks much better - but now the title is incorrect - it relates to 2026-6, not 2026-3
Posted: 27 Sep 2026, 14:17
by Andrew Crocker
Thanks John. Corrected title and heading in the attached. I have asked Michel to distribute to the email distribution as well.
