MX14 Setup Information
Posted: 04 Dec 2014, 07:41
by David L Alston
Gentlemen,
Thank you
Dave
Re: MX14 Setup Information
Posted: 13 Dec 2014, 23:46
by David L Alston
Dave
Posted: 14 Dec 2014, 21:24
by David L Alston
Dave
Posted: 23 Dec 2014, 11:35
by David L Alston
Posted: 16 Jan 2015, 06:51
by Mizi Mat
Hi Dave..
I have one!!!
,,, this is my setup :
Sail : Black Magic
Rigs : from sailsetc
Mizi
Posted: 20 Jan 2015, 08:08
by David L Alston
Mizi,
Dave
Posted: 20 Jan 2015, 16:21
by Mizi Mat
Hi Dave,
Got this boat from thailand builder via my sailing buddy, not much info about rigs measurement and etc,,, just refer to experience skipper from my sailing club,, so far so good, what i can say is,, this boat is quit fast, we have about 15 boat sailing, i manage to get 3rd places most of the race
,,, my sailing skill is not so good, but the boat is fast,,,
Posted: 15 Apr 2015, 07:45
by David L Alston
Tai
1/ Hound position
2/ Spreader position
3/ Spreader length
Dave
Posted: 27 May 2015, 00:32
by Frank Russel
Frank
FRD
Posted: 28 May 2015, 01:44
by David L Alston
Frank ,
Dave
Posted: 28 May 2015, 07:12
by Frank Russel
You can get a Linc fin from Dave Thomas in Melbourne:
joscelle@bigpond.net.au
Frank
Posted: 30 May 2015, 19:50
by David L Alston
Frank,
2018 hits
Dave
Posted: 31 May 2015, 02:16
by Frank Russel
