I've designed and produced various gauges for IOM settings, printed as sticky-backed laminated label tapes and now available for purchase from SAILSetc. The "Hull pack" (GBP 2 SRP) contains a mast rake gauge (reading in degrees) and sheeting gauges for main and jib, also reading in degrees. The "Rig pack" (GBP 3 SRP) contains main and jib draft gauges reading in %, main and jib twist gauges reading in degrees, and boom hole spacing templates for main and jib of each rig, giving one-degree increments. Details at
http://www.onemetre.net/Gauges/Gauges.htm
Gauges for the IOM
- Sail number: GBR 105
Gauges for the IOM
