MX14 Setup Information
David L Alston
- Sail number: 3011
- Club: Leicestershire RYC UK
- Design: Fatboy
Gentlemen,
Thank you
Dave
Gentlemen,
Thank you
Dave
David L Alston
- Sail number: 3011
- Design: Fatboy
Re: MX14 Setup Information
Dave
Dave
David L Alston
- Sail number: 3011
- Design: Fatboy
Dave
Dave
David L Alston
- Sail number: 3011
- Design: Fatboy
Mizi Mat
- Sail number: MAS 87
- Club: Radio Control Sailing Malaysia
- Design: MX14
Hi Dave..
I have one!!!
,,, this is my setup :
Sail : Black Magic
Rigs : from sailsetc
Mizi
I have one!!!
Sail : Black Magic
Mizi
David L Alston
- Sail number: 3011
- Design: Fatboy
Mizi,
Dave
Dave
- MX14 (1).pdf
- (39.15 KiB) Downloaded 7596 times
Mizi Mat
- Design: MX14
Hi Dave,
Got this boat from thailand builder via my sailing buddy, not much info about rigs measurement and etc,,, just refer to experience skipper from my sailing club,, so far so good, what i can say is,, this boat is quit fast, we have about 15 boat sailing, i manage to get 3rd places most of the race
,,, my sailing skill is not so good, but the boat is fast,,,
David L Alston
- Sail number: 3011
- Design: Fatboy
Tai
1/ Hound position
2/ Spreader position
3/ Spreader length
Dave
1/ Hound position
3/ Spreader length
Dave
Frank Russel
- Sail number: AUS 75
- Club: LMRYC/NM/Horizons
- Design: Ellipsis
Frank
FRD
Frank
FRD
- MX14 rigging Guide.pdf
- Current FRD Rigging Guide
- (89.88 KiB) Downloaded 7067 times
David L Alston
- Sail number: 3011
- Design: Fatboy
Frank ,
Dave
Dave
Frank Russel
- Design: Ellipsis
You can get a Linc fin from Dave Thomas in Melbourne: joscelle@bigpond.net.au
Frank
Frank
- Fin weighta.jpg (33.62 KiB) Viewed 86797 times
David L Alston
- Sail number: 3011
- Design: Fatboy
Frank,
2018 hits
Dave
2018 hits
Dave
- Drawing19 Model (1).pdf
- (1.99 KiB) Downloaded 4742 times
Frank Russel
- Design: Ellipsis
