MX14 Setup Information
David L Alston
Sail number: 3011
Club: Leicestershire RYC UK
Design: Fatboy
Post by David L Alston »
Gentlemen,
Thank you
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Re: MX14 Setup Information
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Mizi Mat
Sail number: MAS 87
Club: Radio Control Sailing Malaysia
Design: MX14
Post by Mizi Mat »
Hi Dave..
I have one!!! :D ,,, this is my setup :
Sail : Black Magic
Rigs : from sailsetc
Mizi
David L Alston
Sail number: 3011
Design: Fatboy
Mizi,
Dave
MX14 (1).pdf
(39.15 KiB) Downloaded 7596 times
Mizi Mat
Sail number: MAS 87
Design: MX14
Post by Mizi Mat »
Hi Dave,
Got this boat from thailand builder via my sailing buddy, not much info about rigs measurement and etc,,, just refer to experience skipper from my sailing club,, so far so good, what i can say is,, this boat is quit fast, we have about 15 boat sailing, i manage to get 3rd places most of the race :) ,,, my sailing skill is not so good, but the boat is fast,,, :)
David L Alston
Sail number: 3011
Design: Fatboy
Tai
1/ Hound position
2/ Spreader position
3/ Spreader length
Dave
Frank Russel
Sail number: AUS 75
Club: LMRYC/NM/Horizons
Design: Ellipsis
Post by Frank Russel »
Frank
FRD
MX14 rigging Guide.pdf
Current FRD Rigging Guide
(89.88 KiB) Downloaded 7067 times
David L Alston
Sail number: 3011
Design: Fatboy
Frank ,
Dave
Frank Russel
Sail number: AUS 75
Design: Ellipsis
You can get a Linc fin from Dave Thomas in Melbourne: joscelle@bigpond.net.au
Frank
Fin weighta.jpg (33.62 KiB) Viewed 86798 times
David L Alston
Sail number: 3011
Design: Fatboy
Frank,
2018 hits
Dave
Drawing19 Model (1).pdf
(1.99 KiB) Downloaded 4742 times
Frank Russel
Sail number: AUS 75
Design: Ellipsis
