Seems to me there are 3 options offered:
Eyelet/Luff rings
Grooved mast with sliders
Wire jack stay
Are there any real benefits with any of these or is it just personal choice?
which mailsail link to mast?
- Sail number: GBR3845
- Club: Eastbourne
- Design: TS2 and Shiraz
- Sail number: CAN
Re: which mailsail link to mast?
Hi Dave,
If you want to use one of the lighter French masts, then the Groovey is out, leaving two options.
I think most top sailors have adopted the jack line system - there was a comment on one of the videos from the 2011 Worlds at West Kirby to this effect.
The jack line gives better control of the luff of the sail and prevents it from sliding around the mast. With rings or ties, the luff can slide around the side of the mast and when that happens, the draft of the sail changes and become much flatter as the luff curve is no longer following the shape of the mast.
So to me, no contest - jack lines.
- Club: Eastbourne
Exactly what have noticed, thanks Johnprevents it from sliding around the mast. With rings or ties, the luff can slide around the side of the mast and when that happens, the draft of the sail changes and become much flatter as the luff curve is no longer following the shape of the mast.
My longer term boat Shiraz will have jack lines might treat the TS2 to a new no 1 suit with jack lines. No 2 and no 3 are grooved mast/sliders and will probably leave them as is.
- Sail number: GBR 105
- Design: Pikanto
There are jack lines and there are luff wires (smile)...
http://www.onemetre.net/Build/Jackline/Jackline.htm
The mast acts as a turbulator (turbulence generator) just ahead of the sail. The interesting question is where you'd like this turbulence -- over the windward or leeward side of the sail? Allowing the sail to "slide around" allows the turbulence to flow where you might prefer it.
