AGM Resolution proposal: WC_AGM2006_06
Posted: 17 Jul 2006, 10:12
A Proposal for a resolution for the 2006 AGM has been received:
Posted here for discussion and general comment.Resolution:
WC_AGM2006_06
Proposing NCA / WC Member:
Steve Landeau, NCA for USA
Proposal:
Subject: Mainsail Construction
Rule G.3
Add to G.3(a)(*): The luff must be attached to the mast.
Add to G.3(b)(*): With the exception of a double luff, any method of attachment is allowed.
Remove from G.3(b): Items 4,5,6,7,8.
G.3.3 - Dimensions: Remove luff fitting dimension.
Discussion:
The current rule allows for a full length wire, and an unlimited amount of wires 10mm or less. It seems senseless to disallow anything in-between.
Exec notes:
This is a special resolution and will require a ballot of Certified Owners.
