Page 1 of 4
Single Panel Molded Sails
Posted: 16 Jun 2011, 22:20
by RoyL
Re: Single Panel Molded Sails
Posted: 17 Jun 2011, 17:44
by Peter Allen
Posted: 17 Jun 2011, 23:39
by RoyL
Posted: 18 Jun 2011, 03:17
by Ken Dobbie
The interpretation is at
http://www.iomclass.org/doc-files/Techn ... -IOM-5.pdf
Posted: 18 Jun 2011, 13:28
by Zvonko
Hi Roy and all others
CRO 80 - No 1 jib
CRO 44 - No 1 jib
ISR 37 - No 1 jib
ISR 55 - No 1 jib
6.3.2
Posted: 18 Jun 2011, 20:19
by John Ball
Just my personal thoughts.
Posted: 18 Jun 2011, 22:56
by RoyL
Posted: 18 Jun 2011, 23:06
by Alfonso
Hi John,
Posted: 18 Jun 2011, 23:16
by Bruce Andersen
Alphonso
Posted: 18 Jun 2011, 23:30
by John Ball
Posted: 19 Jun 2011, 00:26
by Ken Dobbie
Alfonso wrote:Hi John,
Interpretation 5/2003 determined that a method of manufacture was not permitted. It would be necessary for a rule change to permit such a method not the reverse as suggested by Alfonso.
Posted: 19 Jun 2011, 08:01
by Barry Fox CAN262
From the IRSA Regulations
Posted: 19 Jun 2011, 18:30
by Bruce Andersen
Posted: 19 Jun 2011, 19:21
by John Ball
Hi Bruce,
Posted: 19 Jun 2011, 19:23
by Marko Majic
Hi everyone,
Personally, I think the most succinct (and ultimately correct) assessment was the first reply from Peter Allen: "They can't be illegal - they all passed event measurement"... Exactly!
Furthermore, I am strongly of the opinion that the said interpretation was
entirely and completely wrong! Yes - it happens that tech committees get it way wrong (they all try to do the best job but, ultimately, they are human): one need not look any further than the recent interpretation that a dual blade rudder on a single shaft is illegal because it contains "openings through which water can flow" (????????) - a perfect example of a completely wrong reasoning that was properly motivated (preventing a perceived undesirable technology where no grounds for it existed in the rules)... I would put the 2003 interpretation in exactly the same "bucket"...
In the interest of complete disclosure and transparency - I'd like all of you on the forum to know that this issue is being discussed by not just the members of the TSC but also the entire Executive as I write this (this is a disclosure part). As per transparency part, I will paste below my own "opinion for the record" (copied directly from my e-mail to the Executive). It is somewhat long-winded (when have I been known to be anything but?
) so for those that do not wish to indulge my copious writing the gist of my opinion is that:
With regards to single-panel sails, I’m afraid I’ve come to the exactly opposite conclusion as the one reached by my good friend Barry... Like him, I will refrain from offering judgement on the validity of the interpretation following the next Class Rules change as I am not a lawyer and do not wish to spend my time digging through IRSA Regulations. Suffice it to say that I think the interpretation was completely wrong (ooops Robert, eh?
)! Much has been and is being said about our class rules being “closed class rules” and what that entails and the kind of silliness a narrow-minded view of the concept can lead to (e.g. are RED boats allowed? Can my deck be different colour than my hull?). The point (in this case at least), however, is that the “closed” applies to what is
covered by the rules – i.e. what you can put in/on the boat and/or make a constituent part of the boat and NOT (and NEVER) covering
how to go about affecting the physical properties of those parts (while in the process of building). Therefore, it is easy to say that e.g. you cannot have a diamond stay on your rig because the rules don’t mention one and they are “closed” rules. However, it doesn’t follow from this that the rules will answer any questions about HOW we get to certain results (and expecting them to tell us that and remain “closed” would turn them into a few thousand pages!). In other words – our rules don’t tell us whether we are allowed to use tools in the process of building – e.g. a hammer, screwdriver, knife, saw (or a heatgun?) – which does not mean that, as per the “closed” clause we are not allowed any – it simply means that (as long as you don’t make that tool a constituent part of the resulting boat) which ones you choose to use is outside the scope of class rules. Likewise, what types of forces (mechanical, thermal) we use in effecting change while in the process of building a boat is also outside of the scope of rules (as presently written). If I were to understand that I am not allowed to exert a physical (mechanical) force while building my next boat – I probably wouldn’t get very far with it... Similarly, I (along with most other, I suspect) use heat to cure my layups. I (sometimes) use both – e.g. I use a torch to heat up a piece of shroud wire (from my big boat) and then use pliers to bend it in various shapes. I don’t think that ANYONE here would for a second seriously suggest that the resulting hook is not class legal because I subjected it to heat or deformed it by exerting mechanical force with pliers? Likewise, I don’t see how a different standards can be applied to the sail construction? The rules are not concerned with HOW you came by the finished product – just the finished product itself. And, as Robert correctly pointed out, single panel sails are class legal (provided they are soft and single-ply).
Now the above discourse
doesn’t, of course, touch on a question that Brad opened up which is:
SHOULD this be class legal? This is a very valid (and pertinent) question and one that bears further discussion among the class leadership, commercial builders and class membership as a whole... If the answer is found to be NO – then we need to find a correct wording to explicitly forbid some of these processes when applied to sail construction only. Personally, I think it might be trickier than we imagine to properly disallow this method (should we decide that is the way to go) – since how do you disallow use of heat in shaping when everyone knows those mylar roles we all use have been formed by heat (heat rolled) at some point in their construction? What is the difference between fabricator doing it and sail-makers doing it? What if I set myself up as a “post-fabricator” that will shape the mylar film accordingly with heat and then sell it to the “actual” sail-maker who simply cuts it to size? Nevertheless – we would cross that bridge when we get to it (if we get to it?)... We should first discuss the merits (or possible dangers) of this new process to find out whether we want further developments in this direction...
Personally, I think this is an interesting area of development and has promise of providing a cheaper product down the road (since after you work out a shape you want, build a mould and iron out any wrinkles in the process – you could trained a reasonably unskilled person to do it instead of requiring a 0.1 mm precision that the broad-seaming process requires). It is analogous to building a mould for a hull and laying it up in that mould... Can you imagine how much one of those BritPops or Pikantos would cost if we had to wait for Brad or Graham to hand plank each hull? (instead of simply building a mould and outsourcing to Croatia
Further (constructive) comments are welcome - either via forum or directly via e-mail to me or members of the Executive. If, however, your sole intention is to rock the boat - please keep in mind that the elections are not until November - so please save your shots until at least late September or early October.
This is an important issue that needs proper class attention (and not political posturing).
Posted: 19 Jun 2011, 20:23
by Bruce Andersen
Posted: 19 Jun 2011, 20:36
by RoyL
Posted: 20 Jun 2011, 22:13
by Robert Grubisa
Hi all
Moulded sails.
Hopefully this helps
Brad
Back to one panel sails. I fully agree with Marko that Interpretation 2003-IOM-5 is totally wrong! At least you know the responsible person for it
Posted: 21 Jun 2011, 01:31
by Brad Gibson
Hi All,
Hi All,
Brad
Brad Gibson
Posted: 21 Jun 2011, 02:50
by Bruce Andersen
Brad
Posted: 21 Jun 2011, 03:22
by Bruce Andersen
Posted: 22 Jun 2011, 04:48
by RoyL
Posted: 22 Jun 2011, 05:35
by Marko Majic
Hi Bruce,
I started drafting an answer (offline) to yours and Roy's queries from a couple of days ago but, by now, the discussion (which was already fractioned into several different points) has taken a whole different tack - which, perhaps, best of all, illustrates the unsuitability of an unmoderated forum as a vehicle for focused discussion. I assure you - the discussion is taking place offline not because anything needs to be hidden but rather to keep it moderated and focused. If you (or anyone else reading this - seriously and please!) wish to be taking part in it I urge them to volunteer to be members of various sub-committees. TSC right now has 2 members (Brad and myself) in addition to the VC Tech (Robert) and probably could use one or two more now that those two other guys are threatening to sit this one out because of perceived conflict of interest and leave me alone in this...
Bruce Andersen wrote:I guess another way of looking at this is perhaps for the next WC's a bunch of us should put together boats that skirt the edge of legality, hoping that VC Tech finds ruling against all of us would be too much hassle! Strength in numbers.
You could sure do that - but why would you want to risk your non-refundable entry fee, travel and accommodation costs and, perhaps most importantly, the opportunity cost of investing a week of your precious disposable time (which, these days, is probably more precious than disposable income) into something when you could be disqualified before the first day of racing on the non-appealable decision of the Event Chief Equipment Inspector and/or the Class International Measurer? Seems too high a price to pay to prove a point...
Bruce Andersen wrote:On a more serious note, shouldn't this question of legality (which still exists) have been dealt with far in advance of the WC? Was an interpretation requested from VCTech regarding single panel moulded sails?
Without a doubt (and I said this much to the Exec) - the CRO and ISR sailors using this equipment and (more specifically) vendor (Zvonko) acted incorrectly by not asking for an interpretation ahead of time which may have alleviated all this trouble... As it so happens - I stand firmly in the belief that the Equipment Inspection team headed by Roger Stollery (and, from what I heard via back-channels, supported by the highly sportsmanlike and cavalier conduct by BG) reached the correct decision in allowing these sails to compete as, it seems pretty clear to me that (as the rules are written right now) they are clearly class legal. However, much of this discussion (and, as I understand it, some unpleasantries AT the event equipment inspection) could have been avoided by a request for interpretation ahead of time (which could have been delayed to mere weeks prior to the event if there was any fear of getting "scooped" through "leaks").
Bruce Andersen wrote:And furthermore, why should it take a bunch of rabble rousers putting numerous posts together for over a week before the EXEC let the general membership know what happened?
Well, by your statement above Bruce, I'm afraid it is clear that you are confusing the role of the Exec in this! They (I, of course, am not a member of the Exec
) have started discussion on this proactively and unofficially having found out about it through (more or less) the same back-channel hear-say (owing mostly to the fact that one member of the Exec was actually AT the event and another, not a member of the Exec but a subcommittee member, was part of the Event Equipment Inspection). In other words, the Exec does not "officially" know any of this yet - and will officially find out when the report is prepared by the Event Organizers (which, no doubt, will include any unpleasantries that may have taken place during Equipment Inspection - along with their recommendations).
But, as an ex-VC Events - no doubt, you should know this already, right?
[I do beg forgiveness if I am wrong in assuming that Roy and you found out about this via "back-channels" too and that Roy didn't actually stumble upon it by "looking at some of the pictures from the recent World Championship" as he stipulated at the outset of this thread. Seems like a justified assumption since I can see how a particularly astute observer might notice the absence of seams but to make a leap from that to the fact that the sails were "moulded" seems rather inspired]
Posted: 22 Jun 2011, 16:19
by RoyL
Posted: 22 Jun 2011, 20:35
by Zvonko
Dear all
Posted: 23 Jun 2011, 02:05
by Bruce Andersen
Given that:
Now the quandry:
Posted: 23 Jun 2011, 06:19
by Barry Fox CAN262
Section 6.2.5
Posted: 23 Jun 2011, 13:05
by Marko Majic
Hi Bruce:
Bruce Andersen wrote:Just when I was thinking this was all going to go away and we could go sailing!
You and me both...
Bruce Andersen wrote:Did these 7 skippers know that these sails would make it through tech inspections in advance of the WC?
Only one person in a whole wide world could have made such a guarantee - not the VC Tech (who was there as a competitor), not Brad Gibson (member of the TSC who was also there as a competitor as well as assisting the equipment inspection team). The only person in a position to make such a guarantee would have been the Chief Equipment Inspector for the event, Roger Stollery, whose decision would have been final and not subject to appeal (AFAIK).
Posted: 23 Jun 2011, 17:01
by Darin Ballington
Zvonko wrote:Dear all
If they are so easy to form what happens when you leave them in the back of the car on a hot day?
Darin
Posted: 23 Jun 2011, 18:36
by Peter Allen
