Page 1 of 2
Voltage indicator / battery indicator legal?
Posted: 28 Nov 2007, 21:32
by Lester
In common with a number of owners, I've fitted Rob Guyatt's little battery voltage flashing display thingy on my pot lid (
http://www.onemetre.net/OtherTopics/Flash/Flash.htm). Turns out this might not meet the IOM class rules:
(1) One receiver.
(2) One rudder control unit.
(3) One sheet control unit.
Posted: 30 Nov 2007, 19:11
by Steve Landeau
Hi, Lester.
Posted: 01 Dec 2007, 07:45
by Barry Fox CAN262
voltage reader
Posted: 03 Dec 2007, 01:24
by Gilbert Louis
Hi,
Gilbert
Posted: 11 Feb 2008, 20:36
by RoyL
Voltage Meter
Posted: 12 Feb 2008, 05:59
by Ken Dobbie
Ken
Posted: 12 Feb 2008, 07:15
by Bruce Andersen
Posted: 12 Feb 2008, 11:43
by Alfonso
I agree 100% with Ken.
Posted: 06 Apr 2008, 07:20
by JThompson
Jim
Posted: 06 Apr 2008, 22:21
by Hiljoball
Posted: 07 Apr 2008, 00:54
by RoyL
voltage reader
Posted: 07 Apr 2008, 12:50
by Gilbert Louis
Posted: 07 Apr 2008, 19:08
by RoyL
Posted: 01 Oct 2008, 16:18
by paulo gomes
Hello from Portugal,
Our very best regards
APMV
Portugal
Posted: 01 Oct 2008, 16:53
by Olivier Cohen
100% OK with that
Posted: 01 Oct 2008, 19:26
by Andy Stevenson
Hi Paulo
Posted: 01 Oct 2008, 20:05
by Steve Landeau
Posted: 01 Oct 2008, 20:15
by Andy Stevenson
Hi Steve
Posted: 01 Oct 2008, 23:11
by Barry Fox CAN262
Posted: 01 Oct 2008, 23:30
by Hiljoball
Posted: 01 Oct 2008, 23:48
by Steve Landeau
Posted: 02 Oct 2008, 00:30
by Barry Fox CAN262
Posted: 02 Oct 2008, 07:19
by RoyL
Posted: 02 Oct 2008, 09:39
by Alfonso
Posted: 02 Oct 2008, 13:18
by Stefano Savelli
hello to all,
Stefano Savelli (Ita54)
Posted: 02 Oct 2008, 17:29
by Don Case
Posted: 02 Oct 2008, 17:30
by Hiljoball
Posted: 02 Oct 2008, 18:46
by Barry Fox CAN262
C5.3
Posted: 03 Oct 2008, 06:14
by Bruce Andersen
Posted: 03 Oct 2008, 07:04
by Barry Fox CAN262
