Spreaders
Posted: 10 Feb 2007, 23:26
by jeolla
Is it a go for carbon spreaders and theirs fittings?
I really can´t find any hints in class-rules. My measurer aren´t sure , but
negative as a consequence.
Posted: 11 Feb 2007, 20:14
by Andy Stevenson
Hi Jeolla,
D.2.1 Hull Materials
E.3.1 Keel and Rudder
F.5.1 Standing Rigging
F.6.1 Running Rigging
G.3.2 Sails
G.4.2 Sails
Posted: 19 Apr 2007, 11:28
by Nigel
Hi Jeolla,
I see no problem. The class rules do not limit the materials for the fittings.
I know a number of boats that have a CF Gooseneck and these have past inspection at Worlds and Europeans a number of times.
Posted: 19 Apr 2007, 23:06
by Hiljoball
Andy, I think you have it right! Spreader material is not defined and so cannot be made of anything! (conversly, if the are not present, they can be made of anything
Posted: 20 Apr 2007, 11:19
by Andy Stevenson
Hi John,
Yes, the Exec can instigate an emergency rule change, with immediate effect, that will require ratification at the next AGM. I believe this is what happened with Texalium the first time round.
Posted: 21 Apr 2007, 19:29
by Lester
Hiljoball wrote:Spreader material is not defined and so cannot be made of anything! [...] I think there are several items that fall into this hole, including other mast fittings that are not covered under the topics for standing rigging, running rigging or booms.
Hi John
IOM CR wrote:The rules in Part II are closed class rules
and
ERS wrote:C.3.2 Closed Class Rules
... we have exactly the problem you identify. In certain areas of the rules, we have the necessary permissions, for example:
F.6 RUNNING RIGGING
F.6.1 MATERIALS
Materials are unrestricted
and
D.2.3 FITTINGS
Elsewhere we have a curious "kind-of" permission for terminators and swivel to be unrestricted:
F.5 STANDING RIGGING
F.5.1 MATERIALS
But in the relevant section (F.3.3 FITTINGS), there are no explicit permissions for things like:
Mainsail halyard fitting
Shroud fitting(s)
Gooseneck
Kicking strap fitting
Headsail stay fitting
Headsail halyard fitting
Mainsail jackstay fittings
Mainsail tack fitting(s)
Mast strut and its fitting
Checkstay fittings(s)
Deck fitting
Added weights
Posted: 21 Apr 2007, 23:01
by Hiljoball
Posted: 22 Apr 2007, 00:31
by jeolla
And so what? My initial question arose from the simple need for some sets of spreaders for some new rigs. I then had some choices. Buy some from known sources at something like 8€ a set or produce some myself. Beeing a true DIY'er I naturally made my own. As thin-wall alu/SS tubes (especially teardrop!) aren't easy to find I therefore visited a local Hobby shop and found some nice flat CF profiles costing a few €'s a metre. Enough for 6-7 sets of spreaders.
Posted: 22 Apr 2007, 05:43
by Hiljoball
But the rules say 'No'.
Posted: 23 Apr 2007, 09:15
by Olivier Cohen
Hiljoball wrote:I empathize with your position. Inexpensive parts should be encouraged. I can buy a CF arrowshaft for less than $10. It would make a great boom.
You can also buy an alloy arrowshaft for less than $10. And the rules say yes
Posted: 26 Apr 2007, 20:22
by jeolla
