Voltage indicator / battery indicator legal?
Post by Lester » 28 Nov 2007, 21:32
In common with a number of owners, I've fitted Rob Guyatt's little battery voltage flashing display thingy on my pot lid (http://www.onemetre.net/OtherTopics/Flash/Flash.htm). Turns out this might not meet the IOM class rules:
(1) One receiver.
(2) One rudder control unit.
(3) One sheet control unit.
Post by Steve Landeau » 30 Nov 2007, 19:11
Hi, Lester.
Post by Barry Fox CAN262 » 01 Dec 2007, 07:45
Gilbert Louis
voltage reader
Post by Gilbert Louis » 03 Dec 2007, 01:24
Hi,
Gilbert
Gilbert LOUIS
www.iomireland.org
V6 - RMG - Blackmagick
IRL41 - Ireland
Post by RoyL » 11 Feb 2008, 20:36
Voltage Meter
Post by Ken Dobbie » 12 Feb 2008, 05:59
Ken
USA NCA Officer
Post by Bruce Andersen » 12 Feb 2008, 07:15
Post by Alfonso » 12 Feb 2008, 11:43
I agree 100% with Ken.
JThompson
Post by JThompson » 06 Apr 2008, 07:20
Jim
Jim Thompson
IOM - USA 370 - Ericca
Hiljoball
Post by Hiljoball » 06 Apr 2008, 22:21
Post by RoyL » 07 Apr 2008, 00:54
Gilbert Louis
voltage reader
Post by Gilbert Louis » 07 Apr 2008, 12:50
Gilbert LOUIS
www.iomireland.org
IRL41 - Ireland
Post by RoyL » 07 Apr 2008, 19:08
paulo gomes
Sail number: POR56
Club: Clube Naval Povoense
Design: BritPop
Portugal
Post by paulo gomes » 01 Oct 2008, 16:18
Hello from Portugal,
Our very best regards
APMV
Portugal
Post by Olivier Cohen » 01 Oct 2008, 16:53
100% OK with that
Post by Andy Stevenson » 01 Oct 2008, 19:26
Hi Paulo
Post by Steve Landeau » 01 Oct 2008, 20:05
Post by Andy Stevenson » 01 Oct 2008, 20:15
Hi Steve
Post by Barry Fox CAN262 » 01 Oct 2008, 23:11
Hiljoball
Post by Hiljoball » 01 Oct 2008, 23:30
Post by Steve Landeau » 01 Oct 2008, 23:48
Post by Barry Fox CAN262 » 02 Oct 2008, 00:30
Post by RoyL » 02 Oct 2008, 07:19
Post by Alfonso » 02 Oct 2008, 09:39
Stefano Savelli
ITA NCA Officer
Post by Stefano Savelli » 02 Oct 2008, 13:18
hello to all,
Stefano Savelli (Ita54)
Stefano Savelli
SAVELLI S.r.l.
Via Bergamo 2/1a
23875 Osnago (LC)
Post by Don Case » 02 Oct 2008, 17:29
Hiljoball
Post by Hiljoball » 02 Oct 2008, 17:30
Post by Barry Fox CAN262 » 02 Oct 2008, 18:46
C5.3
USA NCA Officer
Post by Bruce Andersen » 03 Oct 2008, 06:14
Post by Barry Fox CAN262 » 03 Oct 2008, 07:04
