I can't understand the rules!
Jamestj
Post by Jamestj » 26 Jan 2005, 23:43
A mast and a spar,
A checkstay and a shroud,
A jackstay and a mast jack.
Post by awallin » 27 Jan 2005, 07:41
Post by Bruce Andersen » 28 Jan 2005, 04:12
Much sailing nomenclature is arcane and not very obvious. My suggestion is a beginner sailing book that defines the terms with pictures. Hope that's not too insulting, but is fast and easy.
Jamestj
Post by Jamestj » 28 Jan 2005, 12:55
Many thanks for the help, even the Equipment Rules has pictures which are worth a thousand words.
Not 'all at sea' anymore
Arvin S.
Sailing Terms
Post by Arvin S. » 07 Feb 2005, 12:00
James,
I say, keep at it, the recommendations of the other sailors are sound, the best way to learn is to read up and read up and of course actually go out and see for yourself. I have been sailing for quite some time now, both real boats and RC boats and I can only answer half or less of your questions. The problem is that sailing terms can vary from one place to the other and other terms can be used for a different thing altogether. :(
I will stick my neck out and try to answer some of your questions but don't take them to be 100% correct though. I hope you forgive me though when I say that I think some of your questions you really don't need to know anyway :) I don't and still get to sail no problem :) hehehe! Also please do understand also that some of these terms are not really necessary for RC models.
Muzza
Post by Muzza » 07 Feb 2005, 22:01
I hope this helps.
Cheers.
Murray Buckman
USA 274
Jamestj
Post by Jamestj » 07 Feb 2005, 22:02
Hi Arvin
Thanks for the reply. It seems that every sport has its own vocabulary to keep outsiders guessing. You would have thought that sheets were sails but they are in fact ropes!
Gradually getting my hang of the lingo!
James
