Efficient and good looking carbon finish... how ?
Posted: 16 Jul 2006, 22:36
by Gilbert Louis
Hi,
I have build a rudder in carbon/balsa. It is pretty stiff and to the weigth I wanted but I was looking for the carbon look finish. I think carbon is a nice looking material particularly the twill type.
I managed to get a smooth finish but it didn't look good at all. So I decided to paint it. But for my next one I'd love to keep the carbon look on it.
Some of the carbon hulls I've seen are just simply superb and but I wonder how they get that shiny finish on the carbon ?
Thanks for your help.
Posted: 17 Jul 2006, 03:44
by Steve Landeau
Spray or brush a quality clear coat into the mold first, such as Awlgrip. It can also be sprayed afterwards, but spraying the mold will yield better results.
Posted: 17 Jul 2006, 09:02
by awallin
clear epoxy resin (the same as used for the moulding of the fin), mixed with fumed silica to achieve the right consistency, seems to work OK also. (paint a thin layer into the mould, let cure at elevated temperature until 'dry' to fingertouch and then continue with resin+carbon)
Steve: is the clear-coat you are talking about something like a 2-component clear-coat for car painting ?
Posted: 17 Jul 2006, 09:21
by Steve Landeau
It's a high end 2 part poly that has UV inhibitors in it. I don't use it (I prefer to paint my carbon white), but I know it is used in many different applications, especially for carbon pieces. It is used in both marine and auto industries.
Posted: 18 Jul 2006, 16:16
by Peter Allen
Hummm,Steve as u know i have the Texalium boat and the deck is fading from the sun,i've tried On and Off(like similar to deox) etc so am thinking of a light sanding and a new coat of resin with UV,which is really hard to come by here,but clear coat is really easy to get from the automotive guys,might not be AwlGrip but it's going to be a hi quality paint,Sikkens,Glasurit etc,that's what they use on BMW,Mecerdes etc ????What's your take on that,not to be off topic.Peter
Posted: 18 Jul 2006, 17:46
by Steve Landeau
Peter Allen wrote:Hummm,Steve as u know i have the Texalium boat and the deck is fading from the sun,i've tried On and Off(like similar to deox) etc so am thinking of a light sanding and a new coat of resin with UV,which is really hard to come by here,but clear coat is really easy to get from the automotive guys,might not be AwlGrip but it's going to be a hi quality paint,Sikkens,Glasurit etc,that's what they use on BMW,Mecerdes etc ????What's your take on that,not to be off topic.Peter
I think that if it does not have UV inhibitors added, it will end up looking like it does now after a few years. As I'm sure you have seen on cars, the clear coat will break down after time if it's not waxed and polished regularly (to protect the clear coat).
If that tex boat were mine, I would ask the builder if he could send me a new style deck. then I'd cut that one off and put on a painted one. Solves 2 problems.....
Posted: 19 Jul 2006, 23:36
by Gilbert Louis
Thanks all for your tips I'll try the 2 pack clear coat on the next one. I need to do some fixing with carbon so I might even try it then.
Thx again.
Gilbert
