Modifying Sanwa Super Exzes for iom use
Posted: 05 Jun 2005, 00:13
by Jamestj
I have just bought a Sanwa Super Exzes transmitter and Spektrum modules but don't know how to modify the 'accelerator' stick to work the mainsheet. Can anyone help me please?
Posted: 10 Jun 2005, 02:04
by Rob Guyatt
The short answer is just take out the centring spring. You'll need to remove the back of the tx. First remove the rf module, battery and antenna. The tx can then be used with the stick loose but it is nicer if you can put some drag on it to minimize acidental movement of the stick while racing. That's not a big deal though. I'm using mine 'loose' and it's ok.
Posted: 10 Jun 2005, 10:35
by Jamestj
Hi Rob
I was fiddling with the left stick and unscrewed it quite a long way. Something went click and the stick went floppy. Seems that you don't even need to take the back off to make the changes you suggested! Still, I had better get the bits out in case they short something out.
Thanks for the tip.
