Sheet winches
Posted: 16 Mar 2004, 17:44
by Nigel28
Posted: 17 Mar 2004, 15:27
by spaldi01
Posted: 17 Mar 2004, 18:49
by Greg Vasileff
......Futaba s5801.....
I know there has been some bad rap on these, but I use 5 of them now, some for three years, and I've
never had any problems.
Posted: 18 Mar 2004, 07:22
by Steve Landeau
There are 2 kinds of 5801 owners,
Posted: 18 Mar 2004, 09:18
by edmorales
hello guys!
my iom has the rmg 280c. has anybody tried upgrading a 280c to the d model? is this feasible?
ed morales
Posted: 18 Mar 2004, 10:29
by Brad Gibson
Hi Ed,
As allways it comes down to personal preference (& what can be easily fitted to your hull
BG
Posted: 18 Mar 2004, 11:22
by edmorales
hello brad,
thanks for the input.i guess the upgrade from "c" to "d" would be a wise investment. i'll get to save some bucks. the only downside is that my boat will have to be winchless a few weeks while the winch gets a brain transplant.
regards
ed morales
Posted: 18 Mar 2004, 15:58
by Steve Landeau
Hi, Ed.
I'll bet if you notify Rob that it's coming, you'll only be waiting for shipping time. He'll turn it quickly.
The Aus. Airmail is better than our USPS!. I guess it's cause we're on the west coast, but my shipping is only 3 days.
sheet winches
Posted: 18 Mar 2004, 19:15
by ron
hi ed,
ron
Posted: 18 Mar 2004, 20:12
by Jeff Kay
Jeff
whirlwind winches
Posted: 12 Apr 2004, 14:22
by edmorales
hmmmmm...whirlwind has closed shop
http://www.whirlwindwinches.co.uk/
