Can any one in the UK suggest where I can obtain battery bars, shrink wrap and reasonably priced AA and AAA Nimh rechargeable cells so I can make my own packs please?
Thank you for any help supplied
Graham Allen
Battery pack supplies (make your own)
- Sail number: 88
- Club: Two Islands RYC
- Design: Stealth
- Sail number: GBR3845
- Club: Eastbourne
- Design: TS2 and Shiraz
Re: Battery pack supplies (make your own)
I use 1mm rigid copper wire as use in household electrical fixed wiring, and solder them to the cells, use as big a soldering iron as you can to make the joint quickly without overheating and damaging the cells.
www.7dayshop.com do some "good to go" cells which are well priced and self discharge much less than normal NIMH
You might also consider LiFe or Lipo cells from ebay (or hobbyking) these are prewired and really cheap, have a look at:
http://www.hobbyking.co.uk/hobbyking/st ... Order=desc
They are also lighter than other cells of the same capacity, but at the risk of stating the blindingly obvious, MUST be charged with a lipo compatible charger. If you are curious why, search youtube for Exploding lipo and all will become clear! LiFe cells are less volatile and are also a suitable choice.
