Page 1 of 2
Posted: 08 May 2011, 12:18
by Dave Pickett
And how long do they last?
Posted: 08 May 2011, 18:06
by Hiljoball
Posted: 08 May 2011, 18:27
by chris sullivan
stats - 2s2p cells
3.2 oz/90.7g
50x30x31mm
sully
Posted: 08 May 2011, 22:22
by Bruce Andersen
Posted: 15 May 2011, 03:45
by Peter Allen
Posted: 15 May 2011, 04:14
by Peter Allen
Posted: 15 May 2011, 08:13
by Dave Pickett
Posted: 15 May 2011, 13:03
by Peter Allen
Posted: 17 May 2011, 02:03
by Bruce Andersen
Posted: 17 May 2011, 05:56
by Barry Fox CAN262
Posted: 17 May 2011, 12:15
by Peter Allen
Posted: 17 May 2011, 19:14
by Barry Fox CAN262
I'm happy.
Posted: 19 May 2011, 01:33
by Bruce Andersen
Posted: 19 May 2011, 16:24
by Peter Allen
Posted: 21 May 2011, 05:48
by Bruce Andersen
Posted: 09 Jul 2012, 10:59
by Dave Pickett
Posted: 09 Jul 2012, 12:53
by Peter Allen
Posted: 09 Jul 2012, 13:38
by Peter Allen
Posted: 12 Jul 2012, 19:11
by Peter Allen
Posted: 13 Jul 2012, 10:38
by Dave Pickett
Posted: 14 Jul 2012, 16:20
by Gyula
Posted: 16 Jul 2012, 18:23
by Peter Allen
Posted: 18 Jul 2012, 14:46
by Dave Pickett
Posted: 18 Jul 2012, 16:03
by Peter Allen
Posted: 18 Jul 2012, 20:02
by Dave Pickett
Peter,
I am using this one:
Posted: 18 Jul 2012, 23:44
by Barry Fox CAN262
Posted: 19 Jul 2012, 00:40
by Peter Allen
Posted: 19 Jul 2012, 05:40
by Barry Fox CAN262
Posted: 19 Jul 2012, 17:09
by Dave Pickett
Guys,
To confirm for total clarity
Posted: 19 Jul 2012, 21:56
by Barry Fox CAN262
