winch or arm servo?
Posted: 13 Nov 2010, 15:26
by Dave Pickett
Re: winch or arm servo?
Posted: 13 Nov 2010, 20:38
by Neil Armstrong
Hi David,
Posted: 01 Dec 2010, 01:54
by Aaron Plazier
Dave I am no expert
![Razz :P](./images/smilies/icon_razz.gif)
but I ordered a Hitec HS-785HB Sail winch servo for my 1st boat.
No way in same league as the RMG ones but for me it's fine to do my apprenticeship with.
Posted: 01 Dec 2010, 12:08
by Olivier Cohen
RMG is the easy way.
Posted: 01 Dec 2010, 20:36
by Dave Pickett
HS-785HB
Posted: 01 Dec 2010, 22:54
by Bruce Andersen
Posted: 02 Dec 2010, 05:39
by Aaron Plazier
Rudder servos?
4.8v torque 8kg/cm
6v torque 11kg/cm
Posted: 08 Dec 2010, 23:45
by Patrick Parisienne
Pat
Posted: 09 Dec 2010, 11:08
by Aaron Plazier
thanks for that!
Posted: 18 Dec 2010, 14:16
by Ralph Knowles
Posted: 18 Dec 2010, 19:39
by Dave Pickett
Posted: 09 Jan 2011, 13:58
by Gyula
Posted: 11 Jan 2011, 19:05
by Dave Pickett
