removing numbers in permanent maker ink on dacron sails
Posted: 02 Nov 2008, 13:13
by Gilbert Louis
Hi, I need to remove the permanent ink from a permanent marker on a dacron sail - has anyone done it successfully ?
I've tried nail polish remover which contains acetone but with very little effect apart from making it worse as it spread the ink. So I actually made it worse then before.
reluctant to use white spirit but would it work without damaging the actual sail ?
thanks for your help
Posted: 03 Nov 2008, 00:02
by Steve Landeau
Good timing!
Just last week I videotaped the entire procedure on removing as well as installing ink type sail numbers. I am travelling home from the USA Nationals as I type, but will post the video on Youtube asap. I use acetone and lots of small cut paper towels.
Posted: 03 Nov 2008, 17:53
by Gilbert Louis
oh brilliant - thanks Steve that would be great. safe home and let me know when you've posted the video
Thx again
Posted: 05 Nov 2008, 09:31
by Steve Landeau
Posted: 05 Nov 2008, 09:34
by Steve Landeau
Gilbert, I just realized you are trying to do this on Dacron. It is possible, but much more time consuming. You will not be able to get it perfect I don't think, but it will come off good enough to apply new numbers. You will need more music and more paper towels, and probably a rum or two!
Posted: 11 Nov 2008, 12:26
by Gilbert Louis
Lol - thank you Steve - excellent videos and they'll be very useful to a lot of people. One problem we have here in Ireland is that it seems very few shops if any sell acetone. I haven't been able to find any so I turned towards cheap nail polish remover which contains acetone but to the same purity.
For mylar sails I found -thanks to my wife- that using baking soda works wonders to remove sail numbers in permanent ink. I put a bit of this white power in a bowl with just a little bit of warm water to make a paste of the baking soda. then I also use kitchen towels to wipe the ink on the sails. you need to rub a little more then on your video with the acetone since this is a paste but it is safe for numbers that overlap sail seams. Once most of the ink is gone I finish off with my nail polish remover to wipe off the last bit of ink to make it really clean again. And like you I put the sail to the light to see if it is really clean.
You should try it some day and tell me what you think...
For now I'll try to be more persistent with clearing the number with the nail polish remover as I suspect it to be less effective over pure acetone.
oh and as for the rhum I think I stick to wiskey or a pint or 2 of guinness - and it looks like I'll new a few good CDs
Thanks again Steve. and good luck to get to cape town
Posted: 14 Nov 2008, 13:48
by Peter Allen
I use lacquer thinners found at any paint shop,works as good as acetone.Same procedure as Steve.
Posted: 14 Nov 2008, 19:40
by jeolla
If I may ad a tip concerning removing ink or similar printcolor: Signmakers have invented a technique as follows.
First you use acetone and then wet in wet you remove the mess with pure alcohol of some sort.
It works wonders .
Re: removing numbers in permanent maker ink on dacron sails
Posted: 02 Feb 2014, 15:03
by graham allen
Any idea where the videos have gone from You tube?
Are they available any where else please
Graham
