I am trying to design an IOM and I had read that they can be twitchy to sail. I thought that it would be a good idea to reduce this effect by putting the electrical bits at the back. My reasoning being -
1) This will give the hull a bit of inertia so that it doesn't change direction so quickly
2) The expensive bits can be put all together under one hatch
3) The hatch will be clear of the boom so changing batteries and crystals would be easier, the switch will be more accessible.
4) A bit of weight at the back will help stop the pointed end diving under the water
5) The fin will be placed further forward to balance the boat so there will be more distance between the rudder and fin. This will allow a smaller rudder to have the same effect and the rudder will be further from the turbulence caused by the fin
6) Weight will be saved since the sterering servo will be beside the rudder and the winch drum will replace the transom block
7) The transom is a strong flat bit of wood designed to take the pull of the sails and seems a good place to mount heavy items
8 ) The transom should be out of the way of the spray caused by the hull skipping over the water as the boat takes the chequered flag (or whatever the nautical equivalent is.)
Clearly I have missed something out there since all the plans I have seen drawn up by experienced and successful racers put the weight in the middle.
Now I haven't actually sailed a model yacht yet and I don't intend to until I have a better idea how they work. However finding out is a great experience and draws on so many disciplines.
Oops - I forgot my question. Why is the weight put in the middle of an IOM?
Many thanks.
