MX14 Setup Information
David L Alston
Sail number: 3011
Club: Leicestershire RYC UK
Design: Fatboy
Post by David L Alston » 04 Dec 2014, 07:41
Gentlemen,
Thank you
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Re: MX14 Setup Information
Post by David L Alston » 13 Dec 2014, 23:46
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 14 Dec 2014, 21:24
Dave
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 23 Dec 2014, 11:35
Mizi Mat
Sail number: MAS 87
Club: Radio Control Sailing Malaysia
Design: MX14
Post by Mizi Mat » 16 Jan 2015, 06:51
Hi Dave..
I have one!!! :D ,,, this is my setup :
Sail : Black Magic
Rigs : from sailsetc
Mizi
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 20 Jan 2015, 08:08
Mizi,
Dave
MX14 (1).pdf
(39.15 KiB) Downloaded 5926 times
Mizi Mat
Sail number: MAS 87
Design: MX14
Post by Mizi Mat » 20 Jan 2015, 16:21
Hi Dave,
Got this boat from thailand builder via my sailing buddy, not much info about rigs measurement and etc,,, just refer to experience skipper from my sailing club,, so far so good, what i can say is,, this boat is quit fast, we have about 15 boat sailing, i manage to get 3rd places most of the race :) ,,, my sailing skill is not so good, but the boat is fast,,, :)
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 15 Apr 2015, 07:45
Tai
1/ Hound position
2/ Spreader position
3/ Spreader length
Dave
Frank Russell
Sail number: AUS 5
Club: Northern Mariners
Design: Goth MX7
Post by Frank Russell » 27 May 2015, 00:32
Frank
FRD
MX14 rigging Guide.pdf
Current FRD Rigging Guide
(89.88 KiB) Downloaded 5393 times
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 28 May 2015, 01:44
Frank ,
Dave
Frank Russell
Sail number: AUS 5
Design: Goth MX7
Post by Frank Russell » 28 May 2015, 07:12
You can get a Linc fin from Dave Thomas in Melbourne: joscelle@bigpond.net.au
Frank
Fin weighta.jpg (33.62 KiB) Viewed 43060 times
David L Alston
Sail number: 3011
Design: Fatboy
Post by David L Alston » 30 May 2015, 19:50
Frank,
2018 hits
Dave
Drawing19 Model (1).pdf
(1.99 KiB) Downloaded 3178 times
Frank Russell
Sail number: AUS 5
Design: Goth MX7
Post by Frank Russell » 31 May 2015, 02:16
