This way one does not have to haul a water tank around, where as a simple measuring tool can be used instead.
Thanks,
Herb
Moderator: Lawrie Neish
Certainly, it would be more or less impossible to have a simple draught gauge, as per the M rules, yield the same draught measurement as a flotation tank for all possible designs. The International M class rules have dispensed with total draught in relation to a waterline as measured in a flotation tank. Instead, the M rules now only deal with draught which is limited by a gauge. So the M draught is now controlled in a way that doesn't use the hull waterline as such. As a result, some existing designs could find their fin is a mm or two short of the permitted maximum, and others might find their fin is a mm or two too long, depending upon the exact details of mid-hull beam and fullness in the bilges.Steve Landeau wrote:Without proof of waterline, it will be difficult, if not impossible to use a jig to verify total draft.
with an unrestricted hull depth, there's a possibility to make a very narrow fin-like 'hull' which is very deep. You could put your boat corrector weights at the bottom of this deep(say 150mm) hull.bfox1 wrote: That sure sounds like a simple solution and is consistent with the manner some other classes use to control draught.
However, in this and other discussion there seems to be a lot of concern over doing it that way and a feeling that the hull draught itself needs to be controlled. Not being a designer or student of design for any kind of boat, I don't understand what the effect of a deeper draught is. If that was explained then it might be a way to either stop the talk about a dry measurement system or clarify why one can work if we do as you say.
Hi Anders,VCinfocomms wrote:so, I think not restricting hull depth will result in 'rule braker' boats with funnily shaped very deep hulls.
Hi Gyula,Gyula wrote:Hi
I know that Naviga isn't very popular herebut may I have a word?
That is quite interesting - unlike our own discussion here which tried to gauge the positive impact of the deep hull based solely on the advantage of putting the corrector weights deeper (which, on an IOM, in the best case scenario may amount to 200g or so) it is obvious that under Naviga rules (similar to the US1M CR verbiage) deeper hull places the entire weight of the ballast deeper! And still, as you point out, there doesn't seem to be a decided advantage to going extremely deep! This is very interesting to learn (although not altogether surprising - mildly surprising I guessGyula wrote: In our rules there is no other draft restriction only the depth of the fin measured from the bottom of the hull is limited to 38cm, and the main section of the hull, where the fin is attached, has to be a convex curve. I have seen only a very few boats that has a deep hull (80-90mm), and those has no visible advantage of that.
