Larry Robinson's "Making Model Yacht Sails" bookle
Post by Chairman » 14 Jul 2004, 12:44
For anyone interested in sailmaking, I've just finished editing Larry Robinson's "Making Model Yacht Sails" (part 1 only) booklet and have published it as an "international" edition. I've done this, not to get rich ('cos this isn't going to happen to either me or Larry or anyone else connected with this enterprise!), but because I've spoken to a lot of sailors who want to make sails but don't know the "right" techniques, and who are being misled by incorrect accounts of how this might be done.
From my understanding of sail making, there are two ideas I want to contradict.
The first idea is that you can make sails by accurately cutting a curve on a panel, and then attaching it (stitching, glueing) to another panel. Well, while you might be able to cut a good curve some of the time, your fingers just don't have laser accuracy in them to stick A to B and you'll hardly ever obtain reproducible or reliable results. (It might be possible to butt-join the curved edge to another curved edge with a little more reliability, but this doesn't yield what the Equipment Rules of Sailing define to be a seam. Such a sail couldn't be used in sanctioned IOM competition, though it would be OK in a development class.)
The second idea is that you can drape your panels over a "camber board" and get a nice shape that way. Well, let me be clear about what I'm knocking here. I take a "camber board" to be a length of curved surface, where the curve is like the surface of a cylinder. In this case, your panelled sail will have exactly the same shape as a single unpanelled sail and, if you wanted a three-dimensional shape, you've wasted your time (though the result certainly looks the part).
Larry's booklet is the only source I know which carefully explains the use and construction of a sail block. I am sure that this is really the only way (in your garage, please, not in some specialist workshop!) to make professional sails, to obtain reliable and reproducable three-dimensional shaping, and to be able to tweak and change your shaping as you learn about the whole business.
(Warning: Y'all should know I have ten thumbs and have never made a sail yet. What I have done carefully is to watch and talk to those who do, both professionally and as home builders, and measure the results. Making Larry's booklet available internationally is my way of telling you what I've learned.)
Bob Wells will be able to ship this within the USA (only!) in a couple of weeks, and I expect that it will also be available from Don Ginthner at GBMY in due course. For worldwide sales, contact SAILSetc. Bob Wells' e-mail now is "bob" at "islandinet.com", GBMY is at "rcsailing" at "gbmy.com", and SAILSetc can be contacted through "sales" at "sailsetc.com".
(Edited to clarify butt-joined "seams" in the IOM class.)
