Complete azetone ΙΟΜ for SALE
I bought all the materials but I couldn’t start the project of building, so I sale everything (hull, radio, sails, winch, fittings, mast, boom) ready to build, with instructions
Hull from http://www.azetone.se
Sails from http://www.housemartinsails.co.uk
Winch from http://www.rmgsw.com
All the remaining Deck fittings from http://www.sailsetc.com
Price 700€ + Shipping, via paypal
The boat is in Greece but transport can be arranged
Email Jasonp66gr@yahoo.gr
Quontity Deck fittings
2 Eyebolt 3.5 mm
6 Eyebolt 3 mm
1 Fairlead, PTFE
1 Screw top pot, container for receiver & batteries
1 Epoxy plate 0.5 mm for screw top pot installation in deck
1 Single block, for deck mounting
1 Double block, for deck mounting
1 Tiller arm, plastic with metal collar
1 Tapered bung, for drain hole
1 Mast/deck screw adjuster
1 Deck patch material
1 Alu tube 7.9 mm for screw adjuster and mast pole
1 Dacron 0.7 mm line for sheeting system
1 Rubber O-ring for line sheeting system
1 Water tight switch
1 Stainless push rod for rudder
1 Plastic tube for rudder push rod
1 Plastic hose for antenna through deck
2 Stainless screws for rudder servo attachment
Radio
1 Radio transmitter
1 Radio receiver
1 Rudder servo
1 Winch RMG 280 ES
Boat
1 Deck
1 Hull
1 Fin
1 Rudder
1 Fin box
1 Bow bumper, Silicon
1 Brass tube 5 mm for rudder
1 Brass rod 4 mm for rudder
1 "Fittings kit for fin/bulb: 2 pcs stainless threaded steel rods with 4 nuts and 1
Washer for fin and bulb installation"
1 Rudder servo holder
1 Bulb
2 Stickers Azetone
Building material
1 Glass fibre cloth, approx 0.1 m2, 163 g/m2
1 Glass fibre roving band
3 Strips of 5x5 mm hard wood
2 Hard wood pieces for deck reinforcements
1 Silica tixotropy powder for epoxy 50 ml
1 Epoxy plate 0.5 mm as roof for fin box
Rig
1 Sail suit (main and jib)
1 Stainless wire for forestay 2m, 0.4 mm
1 Luff rings, 11 mm (if round mast is chosen)
1 Mast tube, 11 mm (round or groovy)
5 Bowsies, small 12 mm
1 Dyneema line 36 kg, 5 meter
2 Rigging screw, single end M3
5 Hook, stainless steel, wire
1 Stainless wire 0.55 mm for shrouds, 3.5 m
1 Counterbalance weight, 20 g
1 Head swivel, with ball race, adjustable
1 Main boom kit (profile + fittings pack)
1 Headsail boom kit (profile + fittings pack)
1 Backstay crane, 35 mm
1 Head fitting
1 Spreader kit
1 Eyebolt 3 mm
1 Main sail top hook, stainless
1 Gooseneck
2 Eyebolt 3.5 mm
6 Eyebolt 3 mm
1 Fairlead, PTFE
Radio
1 Radio transmitter
1 Radio receiver
1 Rudder servo
1 Winch RMG 280 ES
Boat
1 Deck
1 Hull
1 Fin
1 Rudder
1 Fin box
1 Bulb
2 Stickers Azetone
Building material
Rig
1 Head fitting
1 Spreader kit
1 Eyebolt 3 mm
1 Gooseneck
- IMG_4176.jpg (47.56 KiB) Viewed 16304 times
- IMG_4175.jpg (39.62 KiB) Viewed 16304 times
- IMG_4174.jpg (45.77 KiB) Viewed 16304 times
Re: Complete azetone ΙΟΜ for SALE
more photos
- IMG_4177.jpg (37.71 KiB) Viewed 16303 times
- IMG_4178.jpg (48.23 KiB) Viewed 16303 times
- IMG_4179.jpg (11.11 KiB) Viewed 16303 times
more photos
- IMG_20141009_080005_0.jpg (57.32 KiB) Viewed 16303 times
- IMG_20141009_080013_0.jpg (64.87 KiB) Viewed 16303 times
- IMG_20141009_075932_0.jpg (82.26 KiB) Viewed 16303 times
more photos
- IMG_4181.jpg (40.16 KiB) Viewed 16303 times
- IMG_4180.jpg (44.53 KiB) Viewed 16303 times
NEW Price 650€ + Shipping, via paypal
NEW Price 550€ + Shipping, via paypal
if someone interesting for parts
1) FUTABA 2 ch Radio transmitter , receiver, Rudder servo 70euro
2) Winch RMG 280 ES 160euro
3) Sail suit (main and jib) 50euro
4) Deck, Hull, Stickers Azetone, fittings 200euro
5) Fin , Fin box, Fittings kit for fin/bulb: 2 pcs stainless threaded steel rods with 4 nuts and 1 washer for fin and bulb installation 20euro
6) Rudder , Brass tube 5 mm for rudder, Brass rod 4 mm for rudder 50euro
7) Riging set , Mast tube 11 mm, Main boom kit (profile,fittings pack), Luff rings, 11 mm, Dyneema line 36 kg, 5 meter, Headsail boom kit (profile + fittings pack) 70euro
you can ask for the shipping cost
- Sail number: 35
- Club: Vointa Tg-Mures
- Design: Corelis
Hello Vasilis!
What type of rig you got A, B, C ?
My interest is only for the sails.
Thank You!
Thank You!
